We have successfully created a great table of contents using
DDX example from Raymond Camden, we are not able though to work out
how we can produce the nesting of the table of contents items.
i.e. Main section.....1
Sub section ......2
Sub section.......3
We have found some documentation that refers to the ability
to do this;
http://livedocs.adobe.com/livecycle/8.2/ddxRef/wwhelp/wwhimpl/common/html/wwhelp.htm?context=DDX&fil...
maxBookmarkLevel
Optional. Specifies the maximum nesting level of bookmarks
used to construct the table of contents. For instance, a value of 1
means that only top-level bookmarks are used to build the table.
Further, only bookmarks that refer to pages within the result
document are included in the table of contents.
We were thinking that if you can specif the maximun level of
bookmarks then you should somewhere be able to set what bookmark
has what level. We have not been able to successfully do this yet.
If anyone has then any help would be very gratefully
received.
