For some reason I must realize strange movement on several sites I recently did.
As one example I add one page from one site: www.bit-coaches.de
That´s the muse (only one page-the landing page).
Using the developer tool The content cannot moved sideways but , at least on my android, I am able to move the page to the left.
I cannot see anything outside.
I realize this issue on my site: www.fotografie-roeder.de as well and www.susannewoerz.de.
I hope with the example from above : www.bit.coaches.de
I can detect my mistake or whatever I am missing here.
Let me add, that on my personal site there´s a pushy panes widget from muse-themes.com
but not on bit-coaches.de .
Thanks in advance
Uwe
Hi Uwe,
I took the privilege of checking your file out, and noticed the issue was because of incorrectly pinned composition menu placed on your site.
After setting each object of your menu i.e the trigger, rectangle, and the whole composition is pinned to top right or right which ever is applicable it seems to work fine.
Here is your file - https://adobe.ly/2ty8aVX I suggest your compare it once with your other files and hope will be able to get through this.
Ankush
Hi Uwe,
Ankush
Well, I feel privileged to get watched out by you, so many thanks, I will check it out and get back to you after checking the uploaded site, being quite sure that your solution helps.
Thanks and best Regards,
Uwe
