The software is up-to-date. When the user tries to combine files (say, a mix of pdf's and Word 2016 docx's) she just gets the little blue circle of death spinning and spinning and it never finishes. This was working fine until about a week ago. I've tried uninstalling/reinstalling, but that didn't fix it. I used Adobe's Acro DC uninstall utility (AdobeAcroCleaner_DC2015) and reinstalling, still didn't fix it. I'm almost to the point where I'm going to rebuild the laptop so I have a clean install, but I'm not even sure if that will fix it. Any ideas?
Hi Works1,
As you said when you combine the files blue circle spinning never finishes, Is it an issue with some particular files that you combine?
Have you tried combining some other files? If not, please create some new word file and then try to combine them.
Check if that works or you still get the spinning wheel.
Could you please let us know the dot version of Adobe Acrobat DC you are using?
To check the dot version, launch the application and go to Help menu. Then select About Adobe Acrobat DC from the drop down list.
You will get a small window with dot version mentioned at the top.
Are you on Mac or Windows? What is the OS version?
We will be waiting for your response.
Meenakshi
It is not limited to just some specific documents. It occurs on a variety of documents, including new files. It is Adobe DC Pro 15.006.30306.
She is using Windows 7 Enterprise, 64-bit.
How can you mark this as assumed answered? I replied to your questions and you offered no fix??? It's not answered, and it's most definitely NOT fixed!
"Assumed Answered" is something that the forum software sometimes applies automatically.
More information: we tried copying the documents to her local C: drive and combining them from there, still no go.
Hi Works1,
As you have mentioned above that you have copied documents to local C drive, please let us know where the files were saved originally.
Have you tried to combine the documents that were saved on the local drive?
If not please try once and check if it works.
Try once to reset the preferences of the application. Refer the steps provided here: How to reset Acrobat Preference settings to default.
Check if it helps in resolving the issue.
Let us know if you have any questions.
Meenakshi
This is still NOT ANSWERED. The files were originally saved on a network share.
Do you have Microsoft Skype for Business 2016 installed?
