I need to be able to send this file to somebody that doesn't have a desktop, they need to be able to save it on their phone, Open it in LR mobile, copy the settings of that picture and paste it onto their own. I know it is possible since I've been send a file like that before and I was able to open it in my mobile version and copy the settings, unfortunately the person that sent it is not very cooperative and doesn't want to give me any information on how she did it.
AngieBenita wrote
Hey guys, I did exactly what you guys told me, Selected the picture, CTRL + S, Save metadata ti file, exported it into the folder. In the preview it shows me that the picture changed (Black and white to make it easy), but as soon as I upload it into dropbox, It is in color again.
WTH
How do you check that in Dropbox? The Dropbox app probably does not use the XMP file to display the image. It simply displays the original preview, which is still color. You’ll have to explain in
...Copy link to clipboard
[ moved from Adobe Creative Cloud to Lightroom Classic CC — The desktop-focused app]
I believe you are looking for the 'Save Metadata' command.
Select your photo or photos
Go the the Metadata menu
Select 'Save Metadata to File' (default KB command CTRL+S)
I believe this saves the sidecar files for your RAW photos.
If you use the DNG format, there is also the 'Update DNG Preview & Metadata' command to write the data into the DNG file
HTH
Are these files perhaps DNG files? If you export a DNG file ‘as original’, the edits will be stored inside the metadata of the DNG, not in a separate XMP file. Same for tiff and jpegs that are exported ‘as original’. XMP files are only used for proprietary raw files. When imported into Lightroom at the receivers end, you edits should come through just fine.
WTH
The XMP sidecar file MUST go along with the RAW file. Both work together. The RAW file is untouched, so it is the full color data. The sidecar files defines how ACR, LR, etc. process the RAW file.
A workaround is to convert the Camera RAW file to the open source DNG format, which includes the sidecar file inside the DNG file wrapper.
Assuming you are working with proprietary Camera RAW files, such as Canon .CR2, Nikon .NEF, Olympus .ORF, etc.:
Alternative: convert the original camera RAW file to the Adobe DNG (Digital NeGative) format. This format wraps the RAW file and the sidecar into one common file format. This can be performed on Import, or on Export.
An advantage of the DNG format is that it is a single file to keep track of. No sidecar required.
I hope that helps.
WTH
How do you check that in Dropbox? The Dropbox app probably does not use the XMP file to display the image. It simply displays the original preview, which is still color. You’ll have to explain in more detail what exactly you are doing.
