using Mac - High Sierra lightoom cc classic 7.4 camera raw 10.4.
I have a 4 x 6 photo paper plus semi gloss loaded in the rear tray of my canon TS8052
I select print template 4 x 6 (1)
Print settings 4 x 6 borderless
print from rear tray
Photo (best)
One would think that this would print a 4 x 6 borderless image
but no...... out comes a 4 x 6 from the rear tray but the image is 2 x 3.
I check all my settings, clear the printer, try again - same result.
Rather than waste any more paper I search on the adobe community page and I come across this from 2015
which basically says the adobe templates are (polite) not brilliant.
"1. Not necessary to select a template! (the supplied adobe templates are mostly for A4 or Letter paper!)
2. Instead- Set your Printer for 6x4 paper in the Page Setup dialog. (as you have done)
3. In [Layout] panel- set all Margins to minimum.
4. In [Layout] panel- set Cell Size sliders to Maximum.
5. In [Image Settings] panel- Set [Zoom to fill]- off, Set [Rotate to Fit]-on"
Low and behold out comes what I wanted.
Adobe has some brilliant people working on lightroom so why doesn't ADOBE use this brilliance to set templates to
do what is in nos. 2-5 when you select (1) 4 x 6.????
bill
Agree fully. All designed for 'Letter' sized paper.
So Adobe tries to be kind to LR users (esp Americans) with some templates as defaults (where 'letter' paper is still a common size in the USofA?).
But down-under in Oz, A4 (and smaller formats for home printing) is more popular, so my Print template browser panel always has the default template folder collapsed and hidden. I only ever select from my own "User templates" that I have designed and save
...Copy link to clipboard
But down-under in Oz, A4 (and smaller formats for home printing) is more popular, so my Print template browser panel always has the default template folder collapsed and hidden. I only ever select from my own "User templates" that I have designed and saved.
Just ignore the "Lightroom Templates" entirely.!
Same here. No-one all over Europe uses Letter format.
I'm now building my own templates since Adobe's are rubbish.
I've always used photoshop to print - much more versatile but a little time consuming.
I just used LR because it was there and a challenge.
