Hi; There are many scripts related to this in the forum. The document has many link files. My file names are as follows; 23.picture.psd 2.graphic.psd . . . I need to remove the DOTS in filenames. I want it to be like this 23picture.psd 2graphic.psd . . . many thanks.
HI,
Just to be clear, you would like to go through each and every link and remove any and all .'s from the file except the one included in the extension, and do all the files exist without the .'s in their names ?
Regards
Malcolm
Hi there,
For this purpose you need to rename all images and relink every image. You can not rename link only.
Thanks for your ideas;
I can change the name for each link. (tomaxi: tomaxxiLINKrename [1.0].jsxbin)
(More than 100+)
But;
each link will control, I want to remove the dot in the link names that are in the dot.
Thank you.
simply removing the dots is risky.
You need a plan what should happen, if there is already a file with the same name after removing the dots.
Uwe
Absolutely right Uwe! It seems impossible for file names to be the same after the dots are cleared 🙂 Thank you.
