Is anyone else having awful problems with the latest Lightroom Classic CC update?
I work on 2 computers:
MacBook Air (11-inch, Early 2014) High Sierra
1.7 GHz Intel Core i7
8 GB 1600 MHz DDR3
iMac Late 2012 High Sierra
3.1 GHz Intel Core i7
Memory 16GB 1600 MHz DDR3
I've had to resort pretty much solely to editing on my MacBook Air because the iMac has serious problems with the update.
Examples of issues are:
- Infinite loading of images - (I upload images with Smart Previews). Have left one image for over 5 minutes and the "Loading" message remains.
- Clicking a Preset, image changes to preset, move cursor towards image, image loses preset, again and again. I have to click on another preset and then the original preset I want and sometimes this works, sometimes it keeps jumping between original image and preset
- Presets not working at all
- Freezing and having to restart
- Twice as long to HDR Merge an image
Just in general everything is SO slow compared to my last version. It makes the workload almost impossible, I can't wait 2-3 minutes for each image to load so I can begin editing.
Any news on a latest fix Adobe?
Any tips - other than reinstalling last version?
Thank you in advance.
Can you post what it says behind ‘License’ in the ‘Help - System Info’ menu?
From the iMac:
Lightroom Classic version: 7.4 [ 1176617 ]
License: Creative Cloud
Language setting: en-GB
Operating system: Mac OS 10
Version: 10.13.4 [17E202]
Application architecture: x64
Logical processor count: 8
Processor speed: 3.1 GHz
Built-in memory: 16,384.0 MB
Real memory available to Lightroom: 16,384.0 MB
Real memory used by Lightroom: 878.5 MB (5.3%)
Virtual memory used by Lightroom: 2,322.8 MB
Memory cache size: 22.4MB
Internal Camera Raw revision: 976
Maximum thread count used by Camera Raw: 5
Camera Raw SIMD optimization: SSE2,AVX
Camera Raw virtual memory: 384MB / 8191MB (4%)
Camera Raw real memory: 386MB / 16384MB (2%)
Displays: 1) 1920x1080
Graphics Processor Info:
Metal: NVIDIA GeForce GT 650M
Application folder: /Applications/Adobe Lightroom Classic CC
Library Path: /Volumes/2017/LR2017/Backups/2018-06-28 1013/LR2017-2.lrcat
Settings Folder: /Users/nickisden/Library/Application Support/Adobe/Lightroom
Installed Plugins:
1) AdobeStock
2) Aperture/iPhoto Importer Plug-in
3) Canon Tether Plugin
4) ColorChecker Passport
5) Export to Photomatix Pro
6) Facebook
7) Flickr
8) Genuine Fractals
9) HDR Efex Pro
10) HDR Efex Pro 2
11) Nikon Tether Plugin
Config.lua flags: None
AudioDeviceIOBlockSize: 512
AudioDeviceName: Built-in Output
AudioDeviceNumberOfChannels: 2
AudioDeviceSampleRate: 44100
Build: 10.0x7
CoreImage: true
GL_ACCUM_ALPHA_BITS: 0
GL_ACCUM_BLUE_BITS: 0
GL_ACCUM_GREEN_BITS: 0
GL_ACCUM_RED_BITS: 0
GL_ALPHA_BITS: 8
GL_BLUE_BITS: 8
GL_DEPTH_BITS: 24
GL_GREEN_BITS: 8
GL_MAX_3D_TEXTURE_SIZE: 2048
GL_MAX_TEXTURE_SIZE: 16384
GL_MAX_TEXTURE_UNITS: 8
GL_MAX_VIEWPORT_DIMS: 16384,16384
GL_RED_BITS: 8
GL_RENDERER: NVIDIA GeForce GT 650M OpenGL Engine
GL_SHADING_LANGUAGE_VERSION: 1.20
GL_STENCIL_BITS: 8
GL_VENDOR: NVIDIA Corporation
GL_VERSION: 2.1 NVIDIA-10.30.25 355.11.10.10.30.120
OGLEnabled: true
GL_EXTENSIONS: GL_ARB_color_buffer_float GL_ARB_depth_buffer_float GL_ARB_depth_clamp GL_ARB_depth_texture GL_ARB_draw_buffers GL_ARB_draw_elements_base_vertex GL_ARB_draw_instanced GL_ARB_fragment_program GL_ARB_fragment_program_shadow GL_ARB_fragment_shader GL_ARB_framebuffer_object GL_ARB_framebuffer_sRGB GL_ARB_half_float_pixel GL_ARB_half_float_vertex GL_ARB_imaging GL_ARB_instanced_arrays GL_ARB_multisample GL_ARB_multitexture GL_ARB_occlusion_query GL_ARB_pixel_buffer_object GL_ARB_point_parameters GL_ARB_point_sprite GL_ARB_provoking_vertex GL_ARB_seamless_cube_map GL_ARB_shader_objects GL_ARB_shader_texture_lod GL_ARB_shading_language_100 GL_ARB_shadow GL_ARB_sync GL_ARB_texture_border_clamp GL_ARB_texture_compression GL_ARB_texture_compression_rgtc GL_ARB_texture_cube_map GL_ARB_texture_env_add GL_ARB_texture_env_combine GL_ARB_texture_env_crossbar GL_ARB_texture_env_dot3 GL_ARB_texture_float GL_ARB_texture_mirrored_repeat GL_ARB_texture_non_power_of_two GL_ARB_texture_rectangle GL_ARB_texture_rg GL_ARB_transpose_matrix GL_ARB_vertex_array_bgra GL_ARB_vertex_blend GL_ARB_vertex_buffer_object GL_ARB_vertex_program GL_ARB_vertex_shader GL_ARB_window_pos GL_EXT_abgr GL_EXT_bgra GL_EXT_bindable_uniform GL_EXT_blend_color GL_EXT_blend_equation_separate GL_EXT_blend_func_separate GL_EXT_blend_minmax GL_EXT_blend_subtract GL_EXT_clip_volume_hint GL_EXT_debug_label GL_EXT_debug_marker GL_EXT_depth_bounds_test GL_EXT_draw_buffers2 GL_EXT_draw_range_elements GL_EXT_fog_coord GL_EXT_framebuffer_blit GL_EXT_framebuffer_multisample GL_EXT_framebuffer_multisample_blit_scaled GL_EXT_framebuffer_object GL_EXT_framebuffer_sRGB GL_EXT_geometry_shader4 GL_EXT_gpu_program_parameters GL_EXT_gpu_shader4 GL_EXT_multi_draw_arrays GL_EXT_packed_depth_stencil GL_EXT_packed_float GL_EXT_provoking_vertex GL_EXT_rescale_normal GL_EXT_secondary_color GL_EXT_separate_specular_color GL_EXT_shadow_funcs GL_EXT_stencil_two_side GL_EXT_stencil_wrap GL_EXT_texture_array GL_EXT_texture_compression_dxt1 GL_EXT_texture_compression_s3tc GL_EXT_texture_env_add GL_EXT_texture_filter_anisotropic GL_EXT_texture_integer GL_EXT_texture_lod_bias GL_EXT_texture_mirror_clamp GL_EXT_texture_rectangle GL_EXT_texture_shared_exponent GL_EXT_texture_sRGB GL_EXT_texture_sRGB_decode GL_EXT_timer_query GL_EXT_transform_feedback GL_EXT_vertex_array_bgra GL_APPLE_aux_depth_stencil GL_APPLE_client_storage GL_APPLE_element_array GL_APPLE_fence GL_APPLE_float_pixels GL_APPLE_flush_buffer_range GL_APPLE_flush_render GL_APPLE_object_purgeable GL_APPLE_packed_pixels GL_APPLE_pixel_buffer GL_APPLE_rgb_422 GL_APPLE_row_bytes GL_APPLE_specular_vector GL_APPLE_texture_range GL_APPLE_transform_hint GL_APPLE_vertex_array_object GL_APPLE_vertex_array_range GL_APPLE_vertex_point_size GL_APPLE_vertex_program_evaluators GL_APPLE_ycbcr_422 GL_ATI_separate_stencil GL_ATI_texture_env_combine3 GL_ATI_texture_float GL_ATI_texture_mirror_once GL_IBM_rasterpos_clip GL_NV_blend_square GL_NV_conditional_render GL_NV_depth_clamp GL_NV_fog_distance GL_NV_fragment_program_option GL_NV_fragment_program2 GL_NV_light_max_exponent GL_NV_multisample_filter_hint GL_NV_point_sprite GL_NV_texgen_reflection GL_NV_texture_barrier GL_NV_vertex_program2_option GL_NV_vertex_program3 GL_SGIS_generate_mipmap GL_SGIS_texture_edge_clamp GL_SGIS_texture_lod
Thanks. I just needed to see the license, to check that you are not another victim of the infamous 'upgrade bug'. That's not the problem, however. I don't have a lot suggestions at this point. Lightroom Classic 7.4 runs fine on both my Macs. One thing you could try to solve this 'loading' problem is to go to Preferences - Performance and check that 'Use Graphics Processor' is turned off.
Thanks JohanEl54. I'll turn off the Graphics Processor and see if that improves.
I'm not sure whether it's a bug that needs to be fixed or a problem with my Mac - but I suspect it could be an update issue if it is running so very slowly on both Macs compared with previous versions.
Will wait for a future update and see if anything improves.
Generally,
When you are seeing poor performance and others are not it is possibly related to a bad install. Reinstalling often makes these issues disappear.
Use the Adobe Creative Cloud App to uninstall Lightroom Classic CC 7.4
Restart your computer (important)
Without opening any other programs, use the Adobe Creative Cloud app to install Lightroom Classic CC again. (this will be from a fresh download)
If after doing this you still have worse performance than your previous version it is time to quantify exactly what tasks are slow and exactly how long they take (in seconds) to complete and how fast they were (in seconds) in a previous version.
Since upgrading to Classic cc 7.4, I can longer import images without LR crashing. Not finding any solutions anywhere else, I tried the re-install recommendation mentioned above. Unfortunately, it did not solve my problem. I've got two client deadlines that I fear I'm going to miss and another looming.
I'll revert back to the previous version LR Classic CC, but should I uninstall 7.4 first?
I had issues with 7.3, which made develop module loading pictures very slow. I did not uninstall it, just installed 7.2 over 7.3 and it made the changes by itself without impacting catalog or presets in any negative way.
