We are working on building a Premiere extension using Kendo UI (a JavaScript front-end framework). So far, everything is working except elements that should be drag/droppable as implemented here: Demo for Drag & Drop Component in Kendo UI jQuery framework
These drag/drop items work fine when loaded in a browser, but attempting to drag from within Premiere does nothing.
If anyone has any insight about why this might be happening or workarounds it would be much appreciated!
Moved from Premiere Pro SDK to Extensions / Add-ons Development by Mod
I tested some D&D cases and got triggered. However, We need to determine ourselves what object dropped.
You can reference HTML sample extension(Adobe official).
Samples/CEP_HTML_Test_Extension at master · Adobe-CEP/Samples · GitHub
Did you test with those Kendo UI Drag and Drop components? If not, how were you binding the drag events to HTML elements?
Inline: <div ondragstart="dragFunction()" ...
Binding with JavaScript: document.addEventListener("dragstart", function(event) { ...
Using jQuery: $('div').on('dragstart', function(event) { ...
I haven't been able to trigger the event with any except the first inline example, and I'm not sure what would be preventing this. I'd like to include several drag-and-drop components that are already created using the Kendo widgets, so if I can figure out what's preventing them from working I'm hoping I can alter something small to get them to work, rather than rewriting them all to trigger drag events in different ways.
I tested it and dragstart event triggerd correctly.
Have you aleady try CEP TEST HTML Sample Extesion?
Thanks for testing this. I've determined that this issue is actually only happening on Mac OSX. After testing with the latest version of Premiere on both Windows 7 and Windows 10, it appears all drag and drop events are being fired correctly.
Everything I previously said is still occurring in the latest version of Premiere on OSX, however. Can anyone else confirm this issue?
