2 Replies Latest reply on Jul 2, 2018 12:26 AM by emiliep89320758
    Update metadata on active document
    emiliep89320758 Level 1
      I'm trying to add new XMP metadata on active document in InDesign CC2018 and it doesn't work.
      If I run my code on a closed indesign file, it works.
      What's wrong ? We could update metadata on active document, couldn't we  ?
      Here is my code :
      // load XMP Library
      function loadXMPLibrary(){
          if ( ExternalObject.AdobeXMPScript){
              try{ExternalObject.AdobeXMPScript = new ExternalObject('lib:AdobeXMPScript');}
              catch (e){alert('Unable to load the AdobeXMPScript library!'); return false;}
          return true;
      var myFile= app.activeDocument.fullName;
      // check library and file
      if(loadXMPLibrary() && myFile != null){
         xmpFile = new XMPFile(myFile.fsName, XMPConst.FILE_INDESIGN, XMPConst.OPEN_FOR_UPDATE);
         var myXmp = xmpFile.getXMP();
      if(myXmp){
          var destNamespace = "myNamespace";
          // define new namespace
          XMPMeta.registerNamespace(destNamespace,"ns2");
          // insert nodes
          myXmp.setProperty(destNamespace,"creator","creator1");
          // put XMP into file
          if (xmpFile.canPutXMP(myXmp)){xmpFile.putXMP(myXmp);}else{alert("Error storing XMP");}
          // close file
          xmpFile.closeFile(XMPConst.CLOSE_UPDATE_SAFELY);
      Got this exception :
      XMP Exception : Open, other failure
        • 1. Re: Update metadata on active document
          Dirk Becker Level 4
          Document file locking might have improved, if it previously worked I would consider that a bug.
          Instead of ExtendScript's XMP library you could work straight on the InDesign document's MetadataPreference object ...
          • 2. Re: Update metadata on active document
            Thanks for your answer.
            I don't know how to add metadata with custom namespace working on the InDesign document's MetadataPreference object.
            In documentation (if I read well), it is written that document.metadataPreferences is a read-only property.
            I tried to do it thanks to that :
            var doc = app.activeDocument;
            var metadataPreferences = doc.metadataPreferences;
            metadataPreferences.setProperty("myNamespace", "myProperty", "myValue");
            It doesn't work, even if I save document after that.
            But, it seems to work with a known namespace like in this example :
            var myDocXMP = app.activeDocument.metadataPreferences;
            var destNamespace = "http://ns.adobe.com/xap/1.0/";
            var destNodeName = "MyTesting";
            var nodeValue = "test value";
            myDocXMP.setProperty(destNamespace, destNodeName, nodeValue);
            It seems like if I want to use custom namespace, I have to use this method :
            var myXML = new XML("<x:xmpmeta xmlns:x=\"adobe:ns:meta/\"><rdf:RDF xmlns:rdf=\"http://www.w3.org/1999/02/22-rdf-syntax-ns#\"><rdf:Description xmlns:TestXMP=\"https://test.wordpress.com/\"></rdf:Description></rdf:RDF></x:xmpmeta>");
            var myXMLfile = File('C:/Users/myUser/Desktop/myTestXMP.xml');
            if ( myXMLfile.open('e') ){
               myXMLfile.write(myXML);
               myXMLfile.close();
               app.activeDocument.metadataPreferences.append(myXMLfile);
               myXMLfile.remove();
            var destNamespace = "https://test.wordpress.com/";
            var destNodeName = "MyTestingNode2";
            var nodeValue = " test value";
            It seems to work on active document.
            Reference :
            Storing custom data into InDesign file via XMP | IndiSnip [InDesign® Snippets]
