Many thanks, Mayank, for your thorough response.
here is the url to the FrameMaker file:
https://share.acrobat.com/adc/document.do?docid=158039af-2257-4880-b093-a92241e8f70f
Yes, prior to reading your suggestion I started looking for a
workaround, and the only one that worked was to convert the
converted .css to plain jane HTML line items for the numbered
lists. Not as nice to look at, but at least I can get the job done.
The big problem with the RH import from FM in this case was
an excess of non-breaking spaces that made it impossible to use the
alignment guides in the ruler interface for fine tuning as I had
successfully done with another FM to RH import. Using plain HTML
line items, the ruler interface only serves to set the left margin,
nothing more. Now if I want consistency across RH projects, I need
to go back to the successful project, change the RH style to HTML
line items, and reapply this style to every singe topic (many
dozens).
The bigger problem is RH failure to break the FM import into
topics based on styles in FM. The FM doc (above link) is
meticulously styled for consistency across "Sections" (Header 3
Italic) but RH fails to make topics as the interface promises. It
makes a few, and includes only fragments of the content where it
does.
The most annoying problem is the failure to import images.
Yes, they are in anchored frames, and still do not appear in RH.
The FM images are nearly 100% GIF, with a few JPG. Nothing esoteric
there. The RH default is JPG, and that makes no difference to me,
nor can I guess why this would cause import to fail. I'll make the
change if you can give me half a reason to expect a different
result, as opposed to computer voodoo.
The alignment of images in their anchored frames in FM is
nearly 100% "at insertion point" which here is in line with the
numbered list text. I have not used "run into paragraph" and I
believe there is no such alignment for anchored frames as simple as
"left." I wish there were. The care and feeding of anchored frames
in FM is unwieldy and weird to put it mildly.
I have also tried the style mapping, which failed to produce
the desired results, or the results specified in the interface for
that matter.
