38 Replies Latest reply on Jul 3, 2018 4:26 AM by Stefan Rakete
    How can I get a total page count of a PDF before placing every page in the PDF?
      Before the [long] spiel, I'm using javascript in InDesign CS3.
      I'd like to create a script that places a multiPage PDF in any number of different impositions. (saddle stitch, 4up signatures, 16up signatures etc.)
      I've easily created a script that iterates through a PDF and places it into a new document as (4,1|2,3), (8,5|6,7) etc, which works for printing in duplex, folding each page in half, and gluing the resulting spines to make a simple thick book (for PDFs with more than, say, 64 pages).
      However, the next step is to re-write the script to create a saddle stitch document (16,1|2,15), (14,3|4,13) ... (10,7|8,9). For this I need to know how many pages there are in the PDF before I start placing the PDF pages, and then making the new document [int((PDFpages+3)/4)] pages long.
      Is there a simple way to get the count of PDFpages without going through a loop and placing the next page from the PDF until the placed page number equals the first page number?
      This way seems wasteful:
      var totPDFPages = 1;
      app.pdfPlacePreferences.pageNumber = totPDFPages;
      myPDFPage = sheetFront.place(File(srcPDF), [0,0])[0];
      var pdfFirstPage = myPDFPage.pdfAttributes.pageNumber;
      while (doneCounting == false) {
      totPDFPages += 1;app.pdfPlacePreferences.pageNumber = totPDFPages;
      if (myPDFPage.pdfAttributes.pageNumber == pdfFirstPage) {
      totPDFPages -=1;
      doneCounting = true;
      alert("PDF has " + totPDFPages + " pages!");exit();
      myPDFPage.remove();
      NB. Javascript above *hasn't* been run, but should look similar once debugged.
      The only thing I've though of to relieve the sheer duplication of placing the PDF twice (once for the count, and once for the imposition), is to create an array of impoPages[counter]=myPDFPage, and then shuffle the pages referenced by the array to the correct sheet and position.
      It'd be much easier to be able to assign pageCount = File(srcPDF).pageCount !!!
      Thanks for any help/tips or even a simple "What are you smoking, man!?"
      Cheers,
      Jezz
        • 1. Re: How can I get a total page count of a PDF before placing every page in the PDF?
          Level 1
          hi
          easiest way - ask user to type number of pages in PDF to impose ;) I do this in my tool ;)
          but if you really need to do this automagically - try to place pages, for example, for step = 100 ?
          place 100 - if placed (no error) place 200, ...
          if after placing 300 you have error - place 250, 275, 262, ...
          divide range when error - 100 / 50 / 25 / 12+13 / 6 (6+7) / 3 (3+4) / 1 (2+1)
          or try to open PDF in Acrobat
          robin
          www.adobescripts.com
          • 2. Re: How can I get a total page count of a PDF before placing every page in the PDF?
            Level 1
            There's another thing that is bugging me...<br /><br />With this code: pdfFirstPage = myPDFPage.pdfAttributes.pageNumber, what happens if (bad practice, but it *could* happen) there are multiple pages with the same folio. <br /><br />I suppose I should iterate through a PDF with alert("Page Number "+ myPDFPage.pdfAttributes.pageNumber); but does myPDFPage.pdfAttributes.pageNumber return a 'real' page Nº like 'Sec 1: iv'  or just a number equivalent to the position in the PDF?<br /><br />Getting off the subject at hand...<br />Does anyone regularly use the Section Prefix?? I've never used it, but wished and hoped for at least *two* 'Section Markers'. Master Pages would benefit from this scenario: "Chapter <marker 1>  <marker 2>  <autoPageNumber>  given that SectionMarkers are treated as one character (making nested styles useless), and therefore causing grief if that 'one' character decides to be much longer than the text box thats holds it... -20,000 kerning, anyone?? /sigh/<br /><br />And a further wish to add to the list: In the Page palette > "View spread at 90°" to allow for a fold across the width of the spread (Calendars, Timetables etc.). Indesign CS4, please!
            • 3. Re: How can I get a total page count of a PDF before placing every page in the PDF?
              Peter Kahrel Adobe Community Professional & MVP
              To find the number of pages in a PDF file I use this functions:
              pp = get_number_of_pages ( File('/d/romani/18-1/rs-18-1.pdf'))
              function get_number_of_pages (f)
                 if (f.exists)
                    f.open ('r');
                    next_line = f.readln ();
                    while ( next_line.indexOf ('/N ') < 0 )
                    var p = next_line.match (/\/N (\d+)\/T/)[1]
                    f.close ()
                    return Number(p)
                 else
                    alert (f.name + ' does not exist.')
                    exit()
              Peter
              2 people found this helpful
              • 6. Re: How can I get a total page count of a PDF before placing every page in the PDF?
                Harbs. Level 6
                Gerald_Singelmann@adobeforums.com wrote:
                > Wicked idea, Peter. I like it :)
                I second that. Very nice!
                Harbs
                • 8. Re: How can I get a total page count of a PDF before placing every page in the PDF?
                  Eric @ MCA Level 3
                  FWIW, if you're on a Mac, Spotlight can tell you this info too. I work in Applescript, but if there's any way to trigger a shell command from JS the theory is the same:
                  --Get result from Spotlight
                  set myResult to do shell script "mdls -name kMDItemNumberOfPages '" & POSIX path of myFile & "'"
                  --Split result on space equals space and grab the second word,
                  -- which should be the page count
                  set oldDelims to AppleScript's text item delimiters
                  set AppleScript's text item delimiters to " = "
                  set myPagesCount to second text item of myResult
                  set AppleScript's text item delimiters to oldDelims
                  As near as I can tell, Spotlight is responsible for all that info in the "More Info" section of the Get Info panel in the Finder.
                  • 9. Re: How can I get a total page count of a PDF before placing every page in the PDF?
                    Level 1
                    Superb!
                    I'm very comfortable with GREP in BBEdit, but really need to expand that into javascript.
                    That snippet of javascript to count the number of pages in a PDF is the sort of lateral thinking I love!
                    Once again, Peter, you're a marvel.
                    --Jezz
                    • 10. Re: How can I get a total page count of a PDF before placing every page in the PDF?
                      Level 1
                      Hi Peter,
                      I found that your method doesn't always work as it is...
                      The header from "InDesign CS2 Scripting Reference.pdf" looks like this:
                      %PDF-1.5
                      1 0 obj<</Contents 2 0 R/Type/Page/Parent 285639 0 R/Rotate 0/MediaBox[0.0 0.0 612.0 792.0]/CropBox[0.0 0.0 612.0 792.0]/BleedBox[0.0 0.0 612.0 792.0]/TrimBox[0.0 0.0 612.0 792.0]/ArtBox[0.0 0.0 612.0 792.0]/Resources<</Font<</C0_0 5899 0 R/C0_1 286131 0 R>>/ProcSet[/PDF/Text]/ExtGState<</GS0 286123 0 R>>>>/StructParents 4>>
                      endobj
                      2 0 obj<</Length 3252/Filter/FlateDecode>>stream
                      However, about three quarters through the PDF there appears a line:
                      285635 0 obj<</Count 1928/Kids[285636 0 R 285792 0 R 285948 0 R]/Type/Pages>>
                      It's not the only /Count object, but it *is* the only occurence of a line containing "/Pages>>", so it's not all doom and gloom. :)
                      totPDFPages = getPDFPageCount(File.openDialog("Choose a PDF File"));
                      function getPDFPageCount(f) {
                        f.open ('r');
                        var gotCount = false;
                      while (! gotCount) {
                        try {next_line = f.readln();}
                         catch (myError) {
                          alert("We've got an error '"+myError+"\pAborting the script");
                          exit();
                        if (next_line.indexOf ('/N ') > 0) { // We've got the easy sort of PDF
                         var p = next_line.match (/\/N (\d+)\/T/)[1];
                         alert("Found a '/N' style PDF, with "+p+" pages");
                         gotCount = true;
                        else if  (next_line.indexOf ('/Pages>>') > 0 ) {  // We probably had to read nearly to the end of the file for the match...
                         var p = next_line.match (/\/Count (\d+)\/K/)[1];
                         alert("Found a '/Count ... /Pages>>' style PDF, with "+p+" pages");
                         gotCount = true;
                      f.close ();
                      return Number(p);
                      --Jezz
                      • 11. Re: How can I get a total page count of a PDF before placing every page in the PDF?
                        Level 1
                        aagh!
                        My try{} catch{} doesn't abort the script if it doesn't find either of the matches, and appears to just keep on trying to read. (endless loop :( )
                        I need to fix for reading past the end of the file.
                        --Jezz
                        • 12. Re: How can I get a total page count of a PDF before placing every page in the PDF?
                          Level 1
                          this catches reading past the end of the file:
                          f.open ('r');
                            if  ( f.eof ) {alert("Aborting the script\nWe've got to the end of the file without finding a page count");
                             f.close();
                             exit();
                             gotCount = true;
                             gotCount = true;
                          f.close ();
                          return Number(p);
                          • 13. Re: How can I get a total page count of a PDF before placing every page in the PDF?
                            Well spotted! I had expected to come across PDF files that had their page count encoded in a different way, but I never have so far. I'll keep your solution in mind.
                            Peter
                            • 14. Re: How can I get a total page count of a PDF before placing every page in the PDF?
                              Level 1
                              this will get almost all pdf pages count.
                              jxswm
                              function getPDFPageCount(f){
                                if(f.alias){f = f.resolve();}
                                if(f == null){return -1;}
                                if(f.hidden){f.hidden = false;}
                                if(f.readonly){f.readonly = false;}
                                f = new File(f.fsName);
                                f.encoding = "Binary";
                                if(!f.open("r","TEXT","R*ch")){return -1;}
                                f.seek(0, 0); var str = f.read(); f.close();
                                if(!str){return -1;}
                                //f = new File(Folder.temp+"/123.TXT");
                                //writeFile(f, str.toSource()); f.execute();
                                var ix, _ix, lim, ps;
                                ix = str.indexOf("/N ");
                                if(ix == -1){
                                  var src = str.toSource();
                                  _ix = src.indexOf("<< /Type /Pages /Kids [");
                                  if(_ix == -1){
                                    ps = src.match(/<<\/Count (\d+)\/Type\/Pages\/Kids\[/);
                                    if(ps == null){
                                      ps = src.match(/obj <<\\n\/Type \/Pages\\n\/Count (\d+)\\n\/Kids \[/);
                                      if(ps == null){
                                        ps = src.match(/obj\\n<<\\n\/Type \/Pages\\n\/Kids \[.+\]\\n\/Count (\d+)\\n\//);
                                        if(ps == null){return -1;}
                                        lim = parseInt(ps[1]);
                                        if(isNaN(lim)){return -1;}
                                        return lim;
                                      return lim;
                                    return lim;
                                  ix = src.indexOf("] /Count ", _ix);
                                  if(ix == -1){return -1;}
                                  _ix = src.indexOf(">>", ix);
                                  if(_ix == -1){return -1;}
                                  lim = parseInt(src.substring(ix+9, _ix));
                                  return lim;
                                _ix = str.indexOf("/T", ix);
                                if(_ix == -1){
                                  ps = str.match(/<<\/Count (\d+)\/Type\/Pages\/Kids\[/);
                                  return lim;
                                lim = parseInt(str.substring(ix+3, _ix));
                                return lim;
                              1 person found this helpful
                              • 15. Re: How can I get a total page count of a PDF before placing every page in the PDF?
                                Level 1
                                Hi all!
                                I am writeing a script in VB that take a pdf file and place the
                                pages acording to the right position and so on.
                                Thank you all for your scripts and ideas.
                                I have a question.
                                What if the pdf contains pages that do not have the same width or height. It hapened to me with some pdf files.
                                So eaven it is slow I'm placeing all the pdf pages (and counting them) and at the same time checking the width and the height to
                                be dhe same in every one of them.
                                I'm scripting for InDesign CS2
                                Nice Coding!
                                • 16. Re: How can I get a total page count of a PDF before placing every page in the PDF?
                                  Level 1
                                  Hi again!
                                  Wel that seams to slow, if you have to many pages It doesn't pay.
                                  While trying to find something for VB, insted of geting and paying for a PDF page counter DLL, searching the internet I come up with this code.
                                  OpenFileDialog1.ShowDialog()
                                  Dim FileName As String
                                  FileName = OpenFileDialog1.FileName
                                  Dim result As Integer
                                  Dim fileReader As System.IO.StreamReader
                                  fileReader = My.Computer.FileSystem.OpenTextFileReader(FileName)
                                  Dim pdfText As String
                                  pdfText = fileReader.ReadToEnd
                                  Dim regx As New Regex("/Type\s*/Page[^s]")
                                  Dim matches As System.Text.RegularExpressions.MatchCollection
                                  matches = regx.Matches(pdfText)
                                  result = matches.Count
                                  MsgBox(result.ToString)
                                  For someone that use VB might be usefull.
                                  Nice coding!
                                  • 17. Re: How can I get a total page count of a PDF before placing every page in the PDF?
                                    Level 1
                                    Hi Ervin,
                                    Take a look at the PlaceMultipagePDF.vbs script that comes with InDesign CS3--it solves this problem without attempting to read the PDF, and may already do most of what you want.
                                    The trouble with opening the PDF and using RegExp to try to get the page count is that you are not guaranteed a.) that you can open the PDF, and b.) that there will be only one instance of the page count in the PDF. The internal structure of PDFs can be quite complicated--especially if multiple PDFs have been merged.
                                    Ole
                                    • 18. Re: How can I get a total page count of a PDF before placing every page in the PDF?
                                      Level 1
                                      Hi Olav,
                                      You are right about a) and b).
                                      What we all want, as far as I'v understud is to get the
                                      PDF total number of pages WITHOUT having to place each of them,
                                      in order to count.
                                      Nice coding!
                                      • 19. Re: How can I get a total page count of a PDF before placing every page in the PDF?
                                        colourit2000 Level 1
                                        Thank you, Eric for the solution in AS.
                                        Although the post is already more than a year old, I just happen to look for it recently.
                                        Tks!
                                        • 21. Re: How can I get a total page count of a PDF before placing every page in the PDF?
                                          Trevorׅ Adobe Community Professional
                                          For Mac the spotlight method will not work if the files are on a remote server / drive.
                                          See https://macscripter.net/viewtopic.php?id=32381 for some methods.
                                          For Windows, IF YOU HAVE ACROBAT INSTALLED, nowadays quite common with CC you can use this.
                                          // For Windows only
                                          function pagesInPDF(path) {
                                              if ($.os[0] !== "W") {return 'Jerk';} // For Windows only!
                                              var vbs;
                                              vbs = [
                                                  'Set doc = CreateObject("AcroExch.PDDoc")',
                                                  'path = "' + new File(path).fsName + '"',
                                                  'doc.open path',
                                                  'returnValue  = doc.GetNumPages',
                                                  'doc.Close()'
                                              ].join('\n');
                                              // Thanks to Harbs for returnValue https://forums.adobe.com/message/8152525#8152525
                                              return app.doScript(vbs, ScriptLanguage.VISUAL_BASIC);
                                              // -1 means doc couldn't be opened
                                          // Change to correct path
                                          // pagesInPDF("C:\\Users\\Trevor\\Creative Cloud Files\\PDF\\dest.pdf")
                                          • 22. Re: How can I get a total page count of a PDF before placing every page in the PDF?
                                            Laubender Adobe Community Professional & MVP
                                            Hi Trevor,
                                            below a solution that is based purely on InDesign, but that obviously can be very much improved with a devide-&-conquer-method for picking numbers. An early version of the below approach can be found here:
                                            Re: Number of pages in imported PDF file?
                                            This time I impoved the code a bit using a temp document's placeGun to count PDF pages and not a temp graphic frame.
                                            The method exploits the fact, that the value for pdfAttributes.pageNumber of a placed PDF will be set to 1 if you want to place a page number that is not possible. For example if you want to place page 21 of a PDF with 20 pages only. InDesign will not throw an error on such an attempt, but will simply place page 1.
                                            Here the code that is working on a graphic frame selected that is holding a placed PDF. You may test with a selected PDF file as well, the function takes a PDF file as argument. But be aware that there is no error handling with the given argument here.
                                                getNumberOfPagesInPDF_FUNCTION-v2.jsx
                                                Script by Uwe Laubender
                                                Using the placeGun to count the number of pages in a PDF.
                                                This is a VERY SLOW version and can be improved very much with a "Divide & Conquer" method.
                                                A first approach can be found in this thread:
                                                2. Re: Number of pages in imported PDF file?
                                                Uwe Laubender Oct 16, 2016 10:22 AM (in response to dev9togo)
                                                https://forums.adobe.com/message/9070532#9070532
                                            // Use case with a selected frame where a PDF is placed into.
                                            // Select the frame and run the script snippet.
                                            var graphicFrame = app.selection[0];
                                            var placedPDFGraphic = graphicFrame.graphics[0];
                                            var pdfFile = File( placedPDFGraphic.itemLink.filePath );
                                            var numberOfPagesOfPDF = getNumberOfPagesInPDF( pdfFile );
                                            alert( "Number of Pages of Placed PDF: "+numberOfPagesOfPDF );
                                            function getNumberOfPagesInPDF( pdfFile )
                                                var maxNumber = 1 ;
                                                var tempDoc = app.documents.add( false );
                                                app.pdfPlacePreferences.pageNumber = maxNumber + 1 ;
                                                tempDoc.placeGuns.abortPlaceGun();
                                                tempDoc.placeGuns.loadPlaceGun( pdfFile , false );
                                                var currentPageNumber = tempDoc.placeGuns.pageItems[0].graphics[0].getElements()[0].pdfAttributes.pageNumber ;
                                                if( currentPageNumber == 1 )
                                                    tempDoc.close( SaveOptions.NO ) ;
                                                    return maxNumber ;
                                                while( currentPageNumber > 1 )
                                                    maxNumber++ ;
                                                    app.pdfPlacePreferences.pageNumber = maxNumber;
                                                    currentPageNumber = tempDoc.placeGuns.pageItems[-1].graphics[0].getElements()[0].pdfAttributes.pageNumber;
                                                    if( currentPageNumber > maxNumber )
                                                    { maxNumber = currentPageNumber };
                                                tempDoc.close( SaveOptions.NO );
                                                return maxNumber-1 ;
                                            Uwe
                                            • 23. Re: How can I get a total page count of a PDF before placing every page in the PDF?
                                              Hi Uwe,
                                              I think it's really better to avoid InDesign's DOM stuff if possible (in some cases it's not).
                                              I tested your method on a 22 page pdf and it took 10329ms my method took 145ms that's 70+ times quicker even on a smallish document.
                                              Even if you divide and conquer then it's still going to be very slow in comparison. For a 3 page doc it still took more than 2 seconds.
                                              One can easily need to paste 200+ page pdfs that's going to take a pretty unbearable amount of  time using InDesign DOM. With the acrobat method it should make hardly any difference in the timing.
                                              Regards
                                              Trevor
                                              • 24. Re: How can I get a total page count of a PDF before placing every page in the PDF?
                                                Hi Trevor,
                                                of course you are right, if you assume that Acrobat Pro DC is available.
                                                My thought on this is to provide this as "last resort" if anything goes wrong with Acrobat or Acrobat is not installed.
                                                Question is how the number of pages in a PDF could be calculated quickly when using InDesign Server.
                                                Uwe
                                                • 25. Re: How can I get a total page count of a PDF before placing every page in the PDF?
                                                  If you can afford InDesign Sever you can afford Acrobat . Or maybe the server can't do doScript, do you know, I don't?
                                                  If that wasn't an option I would still prefer some file reading method, a variation on one of the above.
                                                  But I get the point.
                                                  • 26. Re: How can I get a total page count of a PDF before placing every page in the PDF?
                                                    BarlaeDC Adobe Community Professional
                                                    HI,
                                                    If you are on the server then Acrobat is not licensed for server use.
                                                    Regards
                                                    Malcolm
                                                    • 27. Re: How can I get a total page count of a PDF before placing every page in the PDF?
                                                      Are you saying that it goes against the Acrobat EULA? The Server EULA or something else?
                                                      • 28. Re: How can I get a total page count of a PDF before placing every page in the PDF?
                                                        Trevorׅ  wrote
                                                        … But I get the point.
                                                        Hi Trevor,
                                                        tested a bit on with my approach to make it a bit faster.
                                                        FWIW:
                                                        I went back to place the PDF to a graphic frame instead to the place gun.
                                                        Why?
                                                        Because I could minimize the time for creating a preview image by changing:
                                                        app.displayPerformancePreferences,
                                                        app.displaySettings[0] and
                                                        tempDoc.layoutWindows[0].viewDisplaySetting
                                                        Using the placeGun plus changing the settings above did not minimize the time for loading, a full preview image was generated every time. Using a frame placing the image did the trick. I did this with a temp document showing a layout window.
                                                        Uwe
                                                        • 29. Re: How can I get a total page count of a PDF before placing every page in the PDF?
                                                          HI,
                                                          Yes, it is against the Acrobat EULA.
                                                          Regards
                                                          Malcolm
                                                          • 30. Re: How can I get a total page count of a PDF before placing every page in the PDF?
                                                            BarlaeDC Thanks, that seems to very much go against what acrobat interapplication communication is about.
                                                            Laubender
                                                            Sounds better, about how much % difference does it make?
                                                            I tried a little snippet on the mac
                                                            tell application "Adobe Acrobat"
        open POSIX file "/Users/Trevor/Downloads/Creative Cloud Ecosystem- Developer Engagement and Support.pdf" with invisible
        set doc to document 1
        set c to number of pages of doc
        close doc
                                                            end tell
                                                            c
                                                            I was disappointed at the speed (about 5 seconds) and other potential problems with it. Compared with Windows acrobat interapplication communication method which tool a fraction of a second.
                                                            I will probably post a question next week on the Acrobat SDK forum to see if there's a Mac equivalent.
                                                            The 5 line VBS snippet does a good job.
                                                            Creates an invisible Acrobat process, opens the doc, counts the pages, closes the doc and the Acrobat process and returns the count all in about 150ms. There's no problems with being concerned with whats happening on an open Acrobat instance, dialogs etc.
                                                            As I type I can think of a solution  to that problem, I'll try it out and if it works post it.
                                                            • 31. Re: How can I get a total page count of a PDF before placing every page in the PDF?
                                                              The more people vote for this feature request:
                                                              Please expose a PDF's page count to scripting – Adobe InDesign Feedback
                                                              the bigger the chance that we get it it and can bin all those awful hacks.
                                                              P.
                                                              3 people found this helpful
                                                              • 32. Re: How can I get a total page count of a PDF before placing every page in the PDF?
        IAC is there to allow you to control the Acrobat program on a users desktop, Acrobat has not been built or tested in a server environment.
        And if you are looking for speed then it may be better to investigate the PDF Library, as you could build a simple application ( or even build it into your application) to open, get page number, close. all without requiring Adobe Acrobat to be installed at all.
        Adobe PDF Library SDK
        Regards
        Malcolm
        • 33. Re: How can I get a total page count of a PDF before placing every page in the PDF?
        Hi Peter,
        already voted. Thank you for posting the link here!
        Best,
        Uwe
        • 34. Re: How can I get a total page count of a PDF before placing every page in the PDF?
        Very useful Malcom.
        I was thinking of calling a bash like
        open -na "Adobe Acrobat" "/Users/Trevor/Downloads/Creative Cloud Ecosystem- Developer Engagement and Support.pdf" & echo $!
        and then counting the pages and close as per PID
        • 35. Re: How can I get a total page count of a PDF before placing every page in the PDF?
        Voted too. But it does somewhat go against the crossword value of scripting :-)
        • 36. Re: How can I get a total page count of a PDF before placing every page in the PDF?
        Test Screen Name Most Valuable Participant
        If one wants an Adobe API for PDFs on a server the Adobe PDF Library is available for negotiation. It does not have an IAC interface, C++ is used.
        • 37. Re: How can I get a total page count of a PDF before placing every page in the PDF?
        HI,
        The PDF Library is just a collection of header files and such, but can be used to make just about any kind of application, so you could make your own application with IAC capabilities that you call when you want to count the Page numbers.
        Or you could build and InDesign Server plugin that exposes a scripting interface that uses the PDF library to count the number of pages of a PDF file, you could even go as far as writing your own PDF import plug-in that could be used and it could have functionality to count the pages before import.
        Just to complete the options
        Regards
        Malcolm
        • 38. Re: How can I get a total page count of a PDF before placing every page in the PDF?
        Stefan Rakete Level 2
        Hi All,
        I am using this code snippet with a temporary frame (curTextFrame) to find the number of pages in the pdf. Haven't tested on CC yet.
        Happy about any comment.
        Importiert alle Seiten des PDF Dokumentes
        Besonderheit bei InDesign:
        Wenn app.pdfPlacePreferences.pageNumber  größer ist als die Anzahl der Seiten im
        PDF Dokument, dann platziert InDesign trotzdem eine Seite
        pdfAttributes.pageNumber fängt dann wieder bei "1" an.
        PDFPageCounter.PAGE_NAME_END = 99999;
        PDFPageCounter.doSampleImport = function (curFile, curTextFrame) {
        var curPageNumber = 0;
        for (var i=1; i<PDFPageCounter.PAGE_NAME_END; i++) {
        var curCounter = curPageNumber = i+1;
        app.pdfPlacePreferences.pageNumber = curCounter;
        if (curFile.exists) {
        try {
        curTextFrame.place(curFile);
        } catch (e) {
        $.writeln("cannot place file in InDesign. Corrupt file ?");
        var curPDF = curTextFrame.allGraphics[0];
        var placedPDFPageNumber = curPDF.pdfAttributes.pageNumber;
        if (placedPDFPageNumber == 1) {
        curPageNumber--;
        break;
        return curPageNumber;
