This happened once before , Adobe Tech support helped me. Problem has occurred again and I cannot recall how it was fixed
It is only the latest version Adobe Acrobat - older versions and reader work well
The problem
I double click a .pdf icon OR , going through the application, I tell it to open a.pdf.
I see the document "flash" but I do not see the actual document.
When this happened before , the Adobe Techie found the document was opening behind somewhere.
I recall he seemed to make by desktop (Mac) wall paper disappear and the document was behind it somehow.
I just do not recall how to fix.
Has this happened to any of you?
My open document is hiding somewhere and I would love to find it
(happens with any and all .pdf I try to open in the latest Acrobat Pro.
Will appreciate any help
[moved from Adobe Creative Cloud to PDF workflow and then to Acrobat General]
Hi BobbsieP,
As per the issue description mentioned above, you are unable to view pdf files in Acrobat DC, is that correct?
Could you try opening a few files with Acrobat, go to Window -> Cascade -> Tile and see if that brings up the PDFs.
Let us know if you need any help.
Shivam
