Can someone please provide instructions on how i would align the bottom part of the bullet point text with the first line so it lines up with the text and nit the bullet point its self.
Using the bullet button on the Control Panel will do this for you automatically.
Before:
After:
I'm guessing you put the bullet characters in manually? If so, you will want to pull them back out. Find/change makes this very easy.
~Barb
Before:
After:
~Barb
Hi Aiden,
I would like to know if the steps suggested by Barb worked for you, or the issue still persists.
Kindly update the discussion if you need further assistance with it.
Srishti
I there a discussion on how to customize the bullet/indent/tab/text? InDesign is confusing on this or there aren't enough straight forward controls to manipulate tabs/spacing. It would seem like that should be explained when "default" bullet/tab/spacing isn't wanted.
