Ich möchte in Lightroom in den Vorgaben eine neue Gruppe erstellen.
Normalerweise habe ich das mit Rechtsklick in den Vorgaben-Bereich getan.
Wenn ich das allerdings jetzt am neuen Rechner mache, steht da nur "Ausgeblendete Vorgaben zurück setzen"
Was kann ich tun?
Google translation: Lightroom Default - Create Group. I want to create a new group in Lightroom in Preferences. Normally I have done this with right-click in the preferences area. However, if I do that now on the new computer, there is only "reset hidden preferences" What can I do?
LR 7.3 makes this harder and obscure -- you need to create a dummy preset:
1. In the Presets panel, click + and then Create Preset.
2. In the Create Preset window, click User Presets
3. Select New Group and enter the name
...Copy link to clipboard
Hi Shmunzlerin,
I'm not sure if I understand the issue correctly, could you please explain the issue a bit more? and share your complete work flow, as we need some more information to help you our further.
Sahil
3. Select New Group and enter the name of your group:
4. Click Create to create the preset.
5. Drag one or more presets into the new group. Only then can you delete the dummy preset -- otherwise the group will disappear when it contains no presets!
Thank you!!
बिऊटीटटीडबकं
