Good morning,
I've been watching macOS High Sierra (10.13.5) rapidly running out of memory for some time now. Adobe Acrobat Pro DC (2018.011.200040) with up to 45 GB stands out particularly during the daily work -( At the latest after half an hour I must intervene actively. At the moment I have installed the little helper "Memory Clean" to become "master of the situation" again.
Is that normal or does anyone have a tip?
Thank you
As per the issue description mentioned above, Acrobat DC is consuming high memory on your mac machine, is that correct?
Could you try resetting preferences for Acrobat using the steps given in this link: How to reset Acrobat Preference settings to default. reboot the machine after resetting preferences and try again.
You may also try the troubleshooting steps suggested in the following forum thread: Adobe Acrobat Pro DC uses 45 GB of system memory!
Also, let us know if this happens when you op
...Copy link to clipboard
Also, let us know if this happens when you open a specific pdf or with all the pdfs?
Let us know if you need any help.
Shivam
Thank you for your help.
This behavior occurs with Acrobat open WITHOUT having any PDF opened 😉
The trick with the settings reset seems to work.
I'm continuing to observe the behavior
Have a nice weekend
