I rendered a QuickTime move today RGB+Alpha in After Effects and imported it into the Premiere to layer on top of another file. It does not show at all on the timeline though I can scrub through it just fine in the source Window. I know Adobe dropped support for older codecs, but I have the latest updates for both programs. Shouldn't they be equipped with the latest codecs?
try to go to 'Project Panel', from there right click on your .mov file - modify - interpret footage
and under Alpha Channel try to toggle between use alpha premultiplication from file and
conform alpha premultiplication to premultiplied alpha ... when dropping your .mov file into
the timeline right click on it and set to frame size
check if that helps
if it doesn't try exporting from After Effects as PNG / RGB + Alpha
Alpha shows as black if you do not have any clip or whatever underneath in the timeline.
Check if the clip has alpha in the Preview Area.
It does
Are the QuickTime file and sequence set to the same resolution?
They are
check if that helps
Thank you. I will try this in a second.
Set to frame size did it! (toggling the premultification settings didn't work) Is there something I need to do differently on the front end, or will I have to keep setting to frame size every time I want to do this?
The After Effects comp size is different from the Premiere Pro Sequence
size, or the export settings from AE are set at different size from pp
sequence... should be the same
But they're both 1920 x 1080. Is there another factor?
Post screenshot of properties of the AE mov file and sequence settings.
I checked, and you're right; they're different. Could have sworn I changed the AE comp. Thanks for your help!
No problem you are welcome
I just realized what I was dealing with. My ingest settings were creating proxies that didn't have an alpha channel. Detaching proxies for those files brought them back.
