I have problem when I create a pdf from a powerpoint presentation. The underlining in the powerpoint document is thin, but when it is saved under a pdf format it makes a really thick line which looks ugly. Never had the problem before. Use PDF on the same Macbook pro and problem started surfacing about 1 month ago
Anybody can help?
Martin
OK, you're using Microsoft's technology to create the PDF, as Reader is not capable to doing it.
You should bring this issue up to them.
Try this: Go to the Acrobat menu, then Preferences, Page Display and if "Enhance Thin Lines" is tick, tick it off.
Thanks, just tried it, but still the same even with enhanced thin line ticked off..
How exactly are you converting the file from PP? What command are you using?
Also, what version of Acrobat do you have?
I use save as and then select PDF file for the file format. My Acrobat version is an Acrobat Reader RD version
ok thanks for letting me know
