I've just bought Aurora 2018 and run Lightroom Classic.
When i send 3 images to Aurora to HDR them and press apply it says it's exporting the image but when it returns me to Lightroom the image is not there.
I can find it if i sync the folder but that's a real pain if you have to do it every time you use Aurora.
Is there a lightroom or Aurora setting i need to change.
When i had the trial version of Aurora this worked. When i bought it i also updated the Aurora version 1.2.0.2114
There are no such settings in Lightroom. I don't know Aurora, so I cannot answer if there are settings in Aurora.
You'll have to ask the authors of Aurora.
I have also posted on the Aurora site but this doesn't answer the question about settings
Did you ever figure it out. I just bought Aurora HDR and I am having the same issue. How did you resolve it?
Yes i did solve it
Instead of using "File" - "Plugin extras"
Select the 3 images
Right click on them and select "Export" - "Aurora HDR" - and either "Open source files" or "Edit copy with lightroom adjustments"
It appears there are 3 options to edit in Aurora but only the "Export" option works. Go figure.
