Cp 4 Projects not loading/running
Mar 02, 2009 Mar 02, 2009
I have recently upgraded to Cp4 from Cp3. I have recorded a simple project to test publishing, but when I publish in Cp4 (SWF &HTML) the link seems to load the HTML page, but not run the SWF.
If I do exactly the same thing in CP3, eveything works OK!
Does anyone have any ideas what is going wrong?
Getting started
865
Advisor ,
Which version of Flash Player are you publishing to? Perhaps you are publishing to Flash Player 10 but only have FP 8 installed on your PC? Try and check the Captivate publishing settings.
Other than that I have no idea what could be causing it. I never experienced that problem.
Thanks for the quick response...
Both published to Flash Player 7 (also tried FP8 as well, with same result) :o(
I'm not using Flash 10 player whilst authoring because of the issue seeing Flash Animations in CP3 previews (not sure if that was fixed in CP4) so have Flash Player 9 on my PC. I have also asked other users to check on their browsers without sucess.
I have since published them both to our Moodle LMS, using SCORM and everything is OK!?.
That is fine for the training modules that will be created, but we are also using it to run demonstrations on the Corporate Intranet, hence the need for the HTML link
It is also interesting that the same problem occurs when using the new Send for Review feature.
The reviewers' AIR application shell loads OK, but the CREV file does not load a PLAY button, just the blank screen the HTML link generates.
Advisor ,
So if you upload the content to the web / LMS it works fine but when viewed locally it doesn't work? Are you running the HTML file from your PC or a network drive? If that is the case are you getting a security warning?
Mar 03, 2009 Mar 03, 2009
Not quite....
Uploading to the LMS (moodle) using Scorm works OK.
When viewed locally (on a users PC without Captivate) it works OK
Uploading to the Intranet....Not working,
Sending for Review (CREV) Not working.
As it doesn't appear to be a common CP4 release problem, I will be investigating the upload to the CMS that manages our intranet further. I am training for the next couple of days, but will post any news later this week.
I haven't a clue why the CREV does not load though?. The AIR appilcation loads on the users PC, but not the CREV file that is sent with the email. Reviewers have saved the CREV to their desktop and tried to load from there, but no luck. They seem to have the latest AIR runtime on their PC as well.
The CREV works fine on my PC, which has Captivate on it?! Most confusing.
Mar 05, 2009 Mar 05, 2009
OK,
I can now get the CREV files working on the reviewers PCs.
Although they had WRITE permissions to the shared folder, they also need MODIFY permissions, then the CREV loads OK.
Still trying to work out the HTML link problem with CP4 published projects.
Help resources
