Hey folks,
Most of the article is actually applicable to RH7. Since
writing the article, I have found that in RH7, your topics can have
the same file names as long as they are in different folders. So if
you have your original files in an "en" folder and then import your
translated files into an "fr" folder, you can have all your files
within the same RH project.
The main thing that RH8 provides is the ability to assign
languages at the topic and paragraph levels. In RH7, you can have
only one language for the entire project, so for all topics that
aren't in that language, you have the red squiggly lines underneath
the text. RH7 provides conditional build tags and multiple TOCs,
indexes, and glossaries as described for RH8 in the article. So I
think other than not being able to assign multiple languages within
the project, you'd be able to accomplish everything in the article
using RH7.
Just remember to change the project language in File >
Project Settings before generating any layouts so that the correct
.lng file is applied to your output.
Hope this helps!
--Ben
