2 Replies Latest reply on Jul 7, 2018 1:28 PM by S Hopkins
    Import selected parts of an excel file to InDesign
    samuell92992216
      Hi.
      I wonder if it is possible to import selected parts from an excel file into InDesign.
      I have an excel-file with all of our products data and now I am going to make a pricelist out of it but not with all products. I would like to be able to choose which product that will be imported. Preferable by our article numbers. Is this possible with javascript or some other method?
      I see before me an InDesign document with tables where I fill in the article number and the rest of the table row information is imported from the excel-file. Is it possible or whats best practice?
      The file is being updated continuously which means that products will change rows from time to time, if this has an impact of how to do it most efficiently.
        • 1. Re: Import selected parts of an excel file to InDesign
          S Hopkins Adobe Community Professional
          Yes, it's possible. The sample script below is one simple example of how it could be done. However, when data changes, you would need to rerun the script to create an updated table. There may be more elegant solutions, possibly one using a scriptable spreadsheet (it's been awhile since I supported the PC side with VisualBasic so can't remember if Excel is scriptable).
          (*Requires text frame holding table to be selected
          Works quite well for a medium sized table with only 2 columns*)
          property newList : {}
          tell application "Adobe InDesign CC 2018"
            set selList to selection
            if selList is not {} and class of item 1 of selList is text frame then
            my readCSVFile()
            set selRef to item 1 of selList
            tell document 1
            set x to table 1 of selRef
            tell x
            repeat with i from 1 to count of rows
            set theData to contents of cell 1 of row i
            set matchData to my getMatch(theData)
            set contents of cell 2 of row i to matchData
            end repeat
            end tell
            end tell
            else
            activate
            display alert ("Requres text frame with table selection")
            end if
          end tell
          (*Matches item from table with first element of list items read from the file chosen*)
          on getMatch(theData)
            repeat with i from 2 to length of newList
            set theListItem to item i of newList
            set theItem to item 1 of theListItem
            ignoring white space
            if theItem = theData then
            set theReturn to item 2 of theListItem
            return theReturn
            exit repeat
            end if
            end ignoring
            end repeat
            return ""
          end getMatch
          (*Reads comma return text file exported from spreadsheet*)
          on readCSVFile()
            set rowDelimiter to return
            set colDelimiter to ","
            set fileAlias to choose file
            set fileRef to open for access fileAlias
            try
            set theData to read fileRef as list using delimiter rowDelimiter
            close access fileRef
            on error errStr
            close access fileRe
            activate
            display alert ("unable to read file")
            return
            end try
            set AppleScript's text item delimiters to colDelimiter
            repeat with i from 1 to length of theData
            set thisList to {text items of item i of theData}
            set newList to newList & thisList
            end repeat
            set AppleScript's text item delimiters to ""
          end readCSVFile
          • 2. Re: Import selected parts of an excel file to InDesign
            Of course, you do know that you can link an Excel file as part of its being imported. That way, the table will update when the data changes. The problem would then be to have some way for the table to be modified (to only include the items you want) before importing. Then each time data changes in Excel a modified file is created to replace the original modified file (and update in InDesign).
