I am using zipforms to create documents and can use digital ink (free to me) or docusign (I have to pay for) to sign documents. Once completed, I can view the documents with signatures. If the document was signed with docusign, I click on the *.pdf and it opens very quickly. If the document was signed with Digital Ink it sits there and needs to verify the signatures before opening and can take a couple of minutes. To open the pdf I am using Adobe Acrobat Pro X version 10.1.16.
What can I do to get the *.pdf to open fast like when using docusign or the EDGE will work too?
Thanks in advance. Upgrading to the new version of Adobe seems wrong since everything else seems to be working properly.
Hi Whanenburg,
Sorry for the delay in response.
As per the issue description mentioned above, documents signed using digital ink are slow to open when opening in Acrobat, is that correct?
Could you try adding the documents under privileged location and check if that helps. Refer to this help document for the same: Enhanced security setting for PDFs, Adobe Acrobat
Also, try updating Acrobat to the latest patch using "Check for updates" option under "Help" menu, reboot the machine after installing update and try again. You may also download updates from here: Overview — Release Notes for Legacy Acrobat Products
Let us know if you need any help.
Shivam
Enhanced security setting for PDFs does not help.
No update since 2015 on which I have. 10.1.16. Opening without verification opens the PDF fine but then I do not get the verification.
Please provide a patch since I should not have to upgrade just to possibly fix this. Just to reiterate, the PDF will open, it just needs to go out to the internet and verify the signatures which can take minutes. It only happens with ziplogix digital ink, not with DocuSign, or if I open it in EDGE viewer. I contacted ziplogix and they said once the pdf docs have been created in a PDF, it is not longer their issue.
Bill
Hi Bill,
Would it be possible if you can share the pdf file you are working with to replicate the issue at our end? To share the file here in the forums, refer to the steps given in this link: How to share a file using Adobe Document Cloud
Shivam
Attached is a pdf file that opens slowly. Since there is only one signature, it does not take minutes to open but you will see what it does in verifying signatures.
Thanks for your help.
