Hi all,
My question is as follows I would like to export from lightroom low resolution photos for clients displaying a watermark and sequence of numbers.
1. What size would I make the image, I will be using facebook.
2. I know how to add a watermark and sequence number using the slideshow and exporting.
3. I don't know how to combine all three. The image size, watermark and sequence number. If I go to Export it does not display the sequence number.
When I am in slideshow I don't know what size the image will be exported. I don't know how to tell.
I would appreciate any assistance
Sounds like you need LR/Mogrify.
LR/Mogrify 2 - Add Watermarks, Border and Text Annotions to Images Exported by Adobe Lightroom 2
It says LR2, but it's current.
You don't do this from Slideshow. You do this from the Library Module, you select the desired photos, then you click on the Export button and set the proper settings in the export dialog box.
Thanks for answering I may not have explained myself well.
With the sequence number I need this to appear on front of the photo so that the client can tell me which photo they want.
I used slideshow because I could watermark and put a sequential number on front of the photo. However I do not know how to incorporate reducing the size of the photo as well.
Look into Mogrify, as explained above.
