working with Lists
Participant ,
Mar 03, 2009 Mar 03, 2009
i have bee asked to take a form response and out put it to a table. the response field of the db is populated like so::
"Kelly Wadell | Transferred from POU | 2/1/2009
John Dolce | Transferred from HQ |10/1/2008
David Fargnoli | Transferred from POU | 1/6/2008
after each date is a return when I code my listgetat to capture the return tempVar=listgetat(response, 1,'|')tempVar2=listgetat(response, 2,'|')
the above should produce a table with 3 rows of data
tia
J
Advanced techniques
519
Participant , Mar 03, 2009 Mar 03, 2009
I got it.
<cfloop query="getQ599Response">
<cfif (getQ599Response.question_id EQ 911 OR question_id EQ 1282 ) and isDefined('response')>
<CFSET rep = #response#>
<cfloop list="#rep#" index="i" delimiters="#chr(13)#">
<tr>
<cfloop list="#i#" index="j" delimiters="|"><td>#j#</td></cfloop>
</tr>
</cfloop>
</cfif>
</cfloop>
Valorous Hero ,
So what is your question ? (ie Which part are you having difficulty with)
Participant ,
My problem is the "return" after each set of data. I can only get the first 2 pieces of data in this case Kelly Wadell and Transferred from POU .
my tempVar3, which should be the date is either empty if I set the delimeter to try and find the "return" ( used &ch13; and \n ) or I get the date and the name of the next person.
How do i get the 3 pieces of information into something that can be output to a table with each piece in its own column?
Thanks, the first post the mind was moving faster than the hands.
J
Valorous Hero ,
Treat the value as nested lists. Loop through it using return ( chr(13) and/or chr(10) as the row delimiter. That will split the data into rows. Then split each row into columns using "|" as the delimiter.
If you are using CF8, I would recommend using arrays instead of list functions. The listToArray(..) function now supports empty elements. So your script will not break if one of the values is omitted.
<cfloop list="#response#" index="row" delimiters="...">
<cfset cols = listToArray(row, "|", true)>
... do something with the values here ...
</cfloop>
Participant ,
I got it.
<tr>
</tr>
</cfloop>
</cfif>
</cfloop>
Valorous Hero ,
Good. Keep in mind your script may break/display incorrectly if there are empty values. List functions do not handle empty elements well.
BTW, the separate variable is not needed. Just use the #response# variable.
If you have the opportunity, you should alter that table so that each list element of the response is in it's own field.
Documentation
