Stroke changes when reduced in size
Jul 10, 2018 Jul 10, 2018
•Created icon in Ai CC with brush tool and Wacom tablet.
•When i reduce icon below a certain size the stroke doesn’t scale.
•Have changed settings in Transform - Scale Stroke and Effect to no effect
•Designing Ceramic Pins so gotta fix this... any ideas?
955
Community Expert , Jul 11, 2018 Jul 11, 2018
G,
What happens if you Object>Expand, then try again with stroked paths?
Adobe
Are you going to Preferences>General>Scale Stroke & Effects?
Thank you for replying! So no but I checked and both scale for strokes and corners are checked...
Sent from my iPhone
Garrick Arnold
Yarn Pop
www.yarnpop.com
I think it has something to do with the Live corners function? When I scale
down and the corners thicken I get these little corner widgets? And if I
drag them around It changes the interior of the corner. But change the
sizing of the file and it reverts back to the image I shared originally. I
don't get it: it's just a stroke drawn with a brush... why does it treat
the corners oddly? Any help is appreciated Michelle.
Best,
G
G,
That worked! You're a genius! Wow that was so frustrating.... thank you
thank you thank you!
Best,
Garrick
On Wed, Jul 11, 2018 at 12:53 AM, Jacob Bugge <forums_noreply@adobe.com>
You are welcome, Garrick.
Engaged ,
Scale stroke and effects
Window > Transform > Check the scale stroke and effects
you can make it always active by getting in the preferences (CTRL+K) then check it there
What happens if you choose Object > Path > Outline Stroke before scaling?
Looks like you ran into the blob problem with the calligraphy brush.
Try and Object > Expand appearance before scaling it down.
that seemed to do the trick. thank you for your help! Much appreciated!
Best,
G
On Wed, Jul 11, 2018 at 2:48 AM, Monika Gause <forums_noreply@adobe.com>
Jul 12, 2018 Jul 12, 2018
Thanks Lily! That did the trick... so "blob problem" - is that a thing?
Yeeeeesh! very much appreciate your help.
Best,
G
It has collected some fame in the forums with dozens of threads devoted to it.
