when i press mplay or on the play button nothing happen and the meter don't moove.
Instead of ASIO try the MME option to use the Windows driver and check if you have playback.
it's not in after effect but in the premiere
Check your audio hardware configuration. Edit/Preferences/Audio Hardware
ik but my problem is that i can't play any clip video or audio clip{my meter isn't moving
That could happen If audio hardware is misconfigured. Let's discard that first. Please share your system specs too. That would make everything easier.
Juan
ok it's working but i don't have any sound
Share a screenshot of the audio hardware tab again. When the audio is routed through the Windows Driver, Audio is controlled by Windows like any other app. Check your Windows audio settings. If you can hear audio from any other app or the test sound when you change volume you should have audio from Premiere. Closing and opening Premiere again could help.
Are you using Asio4All or something like that? What is your default audio device on Windows? If you are on Win10 you can change your playback audio device here
I am using a headset
Can you hear audio from Windows? You have to set your Headset as your Playback Audio Device on Windows.
TX FOR EVERYTHING
IT'S OK I FOUND A solution
Can you share it please?
