Hello, I am developing locally with an author instance only and it has always worked. But I think I deleted something in my instance and now it fails when I try to deploy the package. Is there any configuration to turn of deployment to publish? It looks strange that maven tries to deploy to http://localhost:4503/
It already tried a fresh AEM instance and it does also not work. I tried it for the last 4 hours and set everything up as far as I know.
Does the require a system user? I have deleted the user once and recreated it, but maybe I miss something.
Is there a maven or AEM config to solve this issue?
Thanks and regards!
[INFO] --- content-package-maven-plugin:0.0.23:install (install-package) @ test-com-relaunch.apps ---
[INFO] Installing test-com-relaunch.apps (C:\dev\projects\test\test-com-new\test-com-relaunch\apps\target\test-com-relaunch.apps-1.0.0-SNAPSHOT.zip) to http://localhost:4503/crx/packmgr/service.jsp [INFO] HttpMethodDirector - I/O exception (java.net.ConnectException) caught when processing request: Connection refused: connect
[INFO] HttpMethodDirector - Retrying request
[INFO] HttpMethodDirector - Retrying request [INFO] HttpMethodDirector - I/O exception (java.net.ConnectException) caught when processing request: Connection refused: connect
ERROR] Failed to execute goal com.day.jcr.vault:content-package-maven-plugin:0.0.23:install (install-package) on project test-com-relaunch.apps: Connection refused: connect -> [Help 1]
Solved! Go to Solution.
Total Likes
Okay I got it now. It was a wrong config in the parent pom...
Total Likes
Total Likes
Could you please tell me what configuration has given in parent POM? I am also facing the same error. Thanks !!
Total Likes
See this -- it shows building an AEM Project successfully via Maven Archetype 13....
Total Likes
Total Likes
