4 Replies Latest reply on Jul 11, 2018 12:05 PM by Awitmer
    Collect used document fonts and export them to folder
    Awitmer Level 1
      Hello all!
      I am needing a little bit of help with a script I am using to collect a
      documents fonts. It is all working fine, except I don't like how it is
      naming the folder it creates. I want the folder name to be simply "Document
      fonts" and not include the InDesign file name. I would like the folder to be
      in the same directory as the Indesign file. Would somebody be so kind as to
      show me what I need to change in my code? I have the code I am using below.
      If anything isn't clear enough, let me know.
      var
        myFonts = app.documents[0].fonts.everyItem().getElements(),
        myDocument = app.activeDocument,
        len = myFonts.length,
        cFile, cName, outFile, i,
        movefolder = myDocument.fullName + "Document fonts"
        movefolder = Folder(movefolder);
      if (!movefolder.exists) movefolder.create();
      for(i=0;i<len;i++) {
        cFile = File(myFonts[i].location);
        if(!cFile.exists) continue;
        cName = cFile.name;
        outFile = File(movefolder + "/"+ cName);
        cFile.copy(outFile);
      Thanks in advance for your help!
      Awitmer
        • 1. Re: Collect used document fonts and export them to folder
          Laubender Adobe Community Professional & MVP
          replace this:
          with that:
          cFile, cName, outFile, i ;
          var movefolder = File( myDocument.fullName).parent+"/"+ "Document fonts" ;
          movefolder = Folder( movefolder );
          Uwe
          • 2. Re: Collect used document fonts and export them to folder
            Awitmer Level 1
            Thank you soo much! You made my day! It is working great now! I will mark your answer as correct.
            • 3. Re: Collect used document fonts and export them to folder
              And you could check if the active document was ever saved.
              If not, exit, because there is no fullName of the document.
              if(app.documents.length == 0){ exit() };
              if(!app.documents[0].saved){ exit() };
              Put both lines at the beginning of your script.
              However, it would be better to wrap all the code into a self-executing anonymous function like below.
              Simply use return instead of exit() inside this function.
              ( function()
                  // No document open:
                  if(app.documents.length == 0){ return };
                  // Document was never saved:
                  if(!app.documents[0].saved){ return };
                  var myDocument = app.activeDocument;
                  var myFonts = myDocument.fonts.everyItem().getElements();
                  var len = myFonts.length;
                  var cFile, cName, outFile, i ;
                  if (!movefolder.exists){ movefolder.create() };
                  for(i=0;i<len;i++)
                      cFile = File( myFonts[i].location );
                      if( !cFile.exists ){ continue } ;
                      cName = cFile.name;
              Uwe
              • 4. Re: Collect used document fonts and export them to folder
                Awitmer Level 1
                Thank you so much! This looks a lot cleaner and more readable.
