Hi, all,
I am still relatively new to RH. I have Word docs with a
fairly clean template of styles (used previously with Doc-to-Help);
I used the Word doc to generate RH for HTML.
I found that in addition to the styles in the generated CSS
files (<filename>_ns.css and <filename>.css), there are
styles in the Head area of the generated HTML page. For example:
<style type="text/css">
div.whs1 { border:none; border-top:solid #003399 3.0pt;
padding:1.0pt 0in 0in 0in; }
td.whs2 { border-left:none; border-right:none;
border-top:none; border-bottom:none; width:276.0pt; padding:0in
5.4pt 0in 5.4pt; }
td.whs3 { border-left:none; border-right:none;
border-top:none; border-bottom:none; width:274.8pt; padding:0in
5.4pt 0in 5.4pt; }
etc.
From what I can tell, these additional styles add borders and
table cell background colors.
If I add the specifics from these styles to the CSS file,
will that work so that RH doesn't generate these styles on the fly?
The TD info isn't the issue (although it is used throughout the
doc; this is the shading for the Note and Tip callouts); the DIV is
adding styling that I don't want...and I don't want to have to
manually update every page with a level 2 heading (which is what
this DIV is related to!).
Any suggestions?
Thanks in advance!
Kathy
