I have a requirement wherein i have to read xml file from dam and place that data under nodes in JCR.
Kindly help on this!
Total Likes
Please check below article
Creating a Custom Watched Folder Service for Adobe Experience Manager 6.3
Arun
Total Likes
Arun,
Thanks,But this doc tells how to read xml file from our local/desktop.But my question is how from aem dam? Any api and how to use it.
Total Likes
You can use Node API to read XML from DAM.
Example:
Node node = req.getResourceResolver().getResource(qs.toString()+"/jcr:content").adaptTo(Node.class);
InputStream in = node.getProperty("jcr:data").getBinary().getStream();
BufferedReader reader = new BufferedReader(new InputStreamReader(in));
StringBuilder out = new StringBuilder();
String line;
while ((line = reader.readLine()) != null) {
out.append(line);
reader.close();
log.debug("File DATA ==> " + out.toString());
aem63app-repo/ReadFileServlet.java at master · arunpatidar02/aem63app-repo · GitHub
Arun
Total Likes
Reading an XML will not be any different whether it came from the DAM or a folder on the desktop.
To get the file from the JCR - you can use the JCR API to retrieve the file (Arun Patidar showed a code snippet).
Then use Java logic to read the XML file.
Total Likes
