4 Replies Latest reply on Jul 12, 2018 1:53 PM by NicoGallegos
    Delete multiple Em Spaces not working when called outside InDesign
    NicoGallegos Level 1
      Hello! , I'm having an issue with a particular grep expression that doesn't seem to work when I try to execute via an external call, but id does work fine whenever I execute inside InDesign.
      My script aims to delete multiple em spaces and replaces them with a normal space.
      function deleteDoubleEmSpaces() {
          //var doc = app.activeDocument;
          var doc = app.documents.itemByID(iddoc);
          findChangeGrep("~>{2,}"," ","","","","");
      function findChangeGrep(findWhat, changeTo, findStyle, changeStyle, findChrStyle, changeChrStyle) {
          try {
              app.findGrepPreferences.findWhat = findWhat;
              app.changeGrepPreferences.changeTo = changeTo;
              if (findStyle) app.findGrepPreferences.appliedParagraphStyle = findStyle;
              if (changeStyle) app.changeGrepPreferences.appliedParagraphStyle = changeStyle;
              doc.changeGrep();
          } catch (e) {}
          app.findGrepPreferences = app.changeGrepPreferences = NothingEnum.nothing;
      If I run this via the script console from InDesign, it works ok. The regex seems to work fine in the find and change menu. I have other scripts that are called in the same way, and work fine.
      Also, I have used this findChangeGrep() with a simplified grep, and also works.
      My guess is that I have to call the em spaces different, but I can't find how. I have tried things like \\~\\>{2,} ; \\~>{2, }, but nothing seems to works.
      The execution of this script is being made via C# , with a indd.DoScript() method, where indd is an instance of my Indesign App.
      Any clues on where is the mistake? Thanks!
