In the project on the sequence, image sequence DPX is located, after clicking the render and replace, the MOV is rendered and the resulting MOV is one frame smaller than dpx image sequence. And if you do not render the DPX, then when you render the entire project, the places with the DPX image sequence are rendered incorrectly!!! !
In your screengrab the original DPX sequence has timecode with semicolons > ; which normally implies an NTSC style rate ie. 29.97 drop or non drop frame timecode.
25fps normally use only colons > :
It appears that the sequence is not being interpreted correctly. Have you interpreted the frame rate on this DPX sequence or did it come in as 25fps?
problems with DPX were from the beginning of 2018CC ! but it was not so bad yet!
What frame frame rate is your DPX clip, your sequence, and your render and replace settings? There is possibly a mismatch between one of these.
No! I checked all these parameters first! weight frame rate 25
Everywhere the frame rate is 25
Maybe try doing a Transcode using AME?
In Adobe Premiere cc2017 these problems were not! 2017сс with DPX sequences worked very well))) Yes I transcode using After Effects)) but this is not normal
You were very close to the truth)) there is not NTSC), but there is a problem with the frame frequency) when transferring the sequence from the After Effect to the Premiere, the frame frequency was 25.00010 instead of 25
but in Bin it is not visible))
The next question is! why when importing the DPX image sequence the interpretation is so strange 25,0010?
