I want to create a cut thru weathered look on a multiple color / shape object similar to this. (I know about copyright and this is just an example) All the examples I can find to create a grunge or weathered look to allow anything placed under the image are for objects of ONE color. Thanks a million!!!!!
It is a true removal, depending on the texture that you use. Here I used one texture in the mask and put it against a brick wall. The mask had alot of black in it - so a lot of opacity and so much of the brick wall shows thru. It just depends on the mask you pick.
Here is the masking image.
You could try taking an image of a texture, putting it on a layer above the multi-colored art, and use a combination of blend modes and opacity on the texture. That technique will make it apply to the rest of the image regardless of the number of colors.
Agreed but it will not show thru (cut out) to whatever I have behind the logo.
In that case, select both the texture and the multi-colored artwork, go to the Transparency panel, and click Make Mask.
Is the image you're posting above the way you want it to look? If so, your better bet would likely be to bring it into Photoshop, use the Advanced Blending option and choose the Blend IF capabilities...
If you want to keep the "vector" of it, you could Place it into Photoshop to make a Smart Object. Unfortunately, I can't think of a way to get that whole thing back out to Illustrator as vector, though..
Are you trying to do something like this?
If so, you can bring the texture in via an opacity mask. This might get you started.
I have done that. This is what I had. However I wanted it to be a true removal of the logo and showing ANY background that I put behind it. This is as close as I could get.
Just play with different textures til you find one that works.
You can also try Opacity Mask. and make sure the shape or image on the mask with have great transition!
1. Blending mode
2. Opacity
3. Apperances
