I have three cases that either addEventListener to five buttons or addEventListener to certain buttons or removeEventListener from all buttons. However, I failed to removeEventListener from the buttons. What's wrong with my code? Please help, thanks!
var set = true;
var showFeedback1 = showFeedback.bind(this, 0);
var showFeedback2 = showFeedback.bind(this, 1);
var showFeedback3 = showFeedback.bind(this, 2);
var showFeedback4 = showFeedback.bind(this, 3);
var showFeedback5 = showFeedback.bind(this, 4);
stage.addEventListener("tick", checkShowFeedback.bind(this))
function checkShowFeedback() {
// s2 currentRound 1 4 7
if (set) {
if (currentRound % 3 == 1) {
console.log("currentRound % 3 == 1");
for (var i = 0; i < 5; i++) {
if (tempS < 60) {
console.log("temps ", i);
this.scoreSheet_label.gotoAndStop(0);
this.scoreSheet_label.visible = true;
switch(i){
case 0:
this.feedbackCategory1.addEventListener("click", showFeedback1);
break;
case 1:
this.feedbackCategory2.addEventListener("click", showFeedback2);
break;
case 2:
this.feedbackCategory3.addEventListener("click", showFeedback3);
break;
case 3:
this.feedbackCategory4.addEventListener("click", showFeedback4);
break;
case 4:
this.feedbackCategory5.addEventListener("click", showFeedback5);
break;
// s3 currentRound 2 5 8 9
else if (currentRound % 3 == 2 || currentRound == 9) {
console.log("currentRound % 3 == 2 || currentRound == 9");
this.scoreSheet_label.gotoAndStop(1);
else {
console.log("else");
this.scoreSheet_label.visible = false;
this.feedbackCategory1.removeEventListener("click", showFeedback1);
this.feedbackCategory2.removeEventListener("click", showFeedback2);
this.feedbackCategory3.removeEventListener("click", showFeedback3);
this.feedbackCategory4.removeEventListener("click", showFeedback4);
this.feedbackCategory5.removeEventListener("click", showFeedback5);
set = false;
function showFeedback(i) {
category = i;
this.left_arrow_scoreSheet.visible = false;
clearGraph();
this.feedback.visible = true;
triggerShowFeedbackSentence = true;
Well there you go. Every time it enters the frame, the code at the top generates all new showFeedback1, etc. values. This clobbers the previous values, so the removeEventListener calls fail.
Does the frame this code is in get returned to multiple times, or does it only execute once?
It executes multiple times, i will reload the frame in each round.
