I am trying to publish online a 230 page catalog in InDesign 2018... A little over half way through the "Preparing you document" I get an error:
Resource(s) : 25 missing
Out of memory
I hit the button to proceed and it starts uploading, but fails half way???
Help!
I suppose you are using the publish on-line feature of Indesign?
Could you please give more information on your PC (OS and version, hardware configuration...).
Out of memory seams to be a quite precise indication. As long as you do not solve that resource problem, you will not be able to proceed.
Yes, I think getting your configuration would be helpful, this may be specific to your system. Are you able to export as PDF and export as fixed layout ePub?
I've seen another forums thread on memory issues while trying to use Publish Online. In that case, it was a system-based error; when the user restarted the computer, the problem was resolved.
