I fixed it so it isn't throwing errors now. BUt it also isn't
doing what I need it to do. Now I am down to 2 errors left.
1. when you update, or add a record, the code on this page
doesn't catch it and put up the "you have successfully updated ..."
2. If you go to this page and just want to see the records
from just the category you chose, lets say I am looking at all the
projects in the category NYS made widgets, when you hit next, it
throws an error, because there are more then 5 records for the
page.
This is how the code looks now:
<!--- This is the query with the error, It runs the
project records and either brings them all up or just those in the
category chosen from another page. --->
<cflock timeout="10" type="exclusive"
scope="application">
<cfquery name="getProjects"
datasource="#APPLICATION.dataSource#">
SELECT Projects.Name AS PName, Projects.ProjectID AS ID,
Projects.CategoryID,
Categories.Name AS CName, Categories.CategoryID
FROM Projects INNER JOIN Categories ON Projects.CategoryID =
<cfif StructKeyExists(url, 'CategoryID')>
WHERE Categories.CategoryID = <cfqueryparam
CFSQLType="CF_SQL_INTEGER" value="#URL.CategoryID#" />
AND Categories.CategoryID = Projects.CategoryID
ORDER BY Projects.Name
<cfelse>
ORDER BY Categories.Name
</cfif>
</cfquery>
<cfset rowsPerPage = 6>
<cfparam name="URL.startRow" default="1"
type="numeric">
<cfset totalRows = getProjects.recordCount>
<cfset endRow = min(URL.startRow + rowsPerPage - 1,
totalRows)>
<cfset startRowNext = endRow + 1>
<cfset startRowBack = URL.startRow - rowsPerPage>
</cflock>
<!--- End project file code --->
<!--- This code runs the success in updating your #record#
<cfif isDefined("URL.ProjectID")>
<cfquery name="zlnbbXX"
datasource="#APPLICATION.dataSource#" maxrows="1">
Projects.CategoryID
FROM Projects
WHERE ProjectID = #URL.ID#
</cfquery>
</cfif>
<!--- end code--->
<head>
</head>
<body>
<!--- code for Success update record --->
<cfif isDefined("URL.RecordID")>
<cfoutput query="zlnbbXX">
<font color="##990000" face="Verdana, Arial, Helvetica,
sans-serif" size="2"><b>Updates Have Successfully Been
Applied
to:</b><br><u>#PName#</u></font><br></cfoutput></cfif>
<!--- end success --->
<!-- records and next / prev nav --->
<cfoutput>
Displaying <b>#URL.startRow#</b> to
<b>#endRow#</b> of <b>#totalRows#</b>
Records</font>
<cfset urlVars = "">
<cfif startRowBack GT 0>
<cfset urlVars = "startRow=#startRowBack#">
</cfif>
<cfif structKeyExists(url, 'categoryID')>
<cfset urlVars = urlVars &
"categoryID=#categoryID#">
</cfif>
<a href="#CGI.script_name#?#urlVars#" class="nav"><
Previous Records</a>
<cfset urlVars = "" >
<cfif startRowNext lte totalRows>
<cfset urlVars = "startRow=#startRowNext#">
</cfif>
</cfif>
<a href="#CGI.script_name#?#urlVars#" class="nav">Next
></a>
</cfoutput>
<!--- end next / prev code --->
<!-- records to edit --->
<cfloop query="getProjects" startRow="#URL.startRow#"
endrow="#endRow#"><cfset class = iif(getProjects.currentRow
mod 2 eq 0, " 'DataA' ", " 'DataB' ")>
<cfoutput>
#PName#
#CName#
<form name="myform" action="Action.cfm" method="post">
<input type="hidden" name="ID" value="#ID#">
<input type="submit" ... More code here>
</cfoutput>
</cfloop>
</body>
This is my code for the update database. It is supposed to be
passing an id if there is a new record addd to teh db so it will
catch the code on the other page and post out the "success, you
have updated your..."
<cfif form.id eq 0>
<cfquery datasource="#APPLICATION.dataSource#">
INSERT INTO Projects
(Name, Body, CategoryID)
VALUES
(<cfqueryparam cfsqltype="cf_sql_varchar"
value="#form.proj_name#">,
<cfqueryparam cfsqltype="cf_sql_longvarchar"
value="#form.PDSeditor#">,
<cfqueryparam value="#form.CategoryID#"
cfsqlType="CF_SQL_INTEGER">)
</cfquery>
<cflocation url="project-manager.cfm?ID=#Form.ID#">
<cfelse>
UPDATE Projects
SET
Projects.Name=<cfqueryparam cfsqltype="cf_sql_varchar"
Projects.Body=<cfqueryparam cfsqltype="cf_sql_longvarchar"
Projects.CategoryID=<cfqueryparam
value="#form.CategoryID#" cfsqlType="CF_SQL_INTEGER">
WHERE ProjectID = <cfqueryparam value="#form.ID#"
</cfquery>
<cfquery name="ZFetchID"
SELECT ProjectID
FROM Projects
WHERE Name = <cfqueryparam cfsqltype="cf_sql_varchar"
</cfquery>
<cflocation
url="project-manager.cfm?id=#ZFetchID.ProjectID#">
</cfif>
Maybe I missed something?
Also, my previous button does not disappear when there are no
records to go back to. It is always there.
Thank you
CFmonger
