Hi all
I would like to ask about document size after sign with .p12 certificate. Long time worked everithing properly. Before sign the pdf doc has around 130kB, after sign it was around 180kB. But now after sign the document has 3.03MB. What happend?
Thanks in advance
Regards
Ondrej
Hello Ondrej,
We're sorry for the trouble you had, please refer to the following Adobe discussions and articles and try the suggestions marked as helpful and correct File Size Growth when digitally signed
Electronically signing PDF file increases file size by approximately 3 MB
File size increases dramatically after digital signature
What is the dot version of Adobe Reader installed? To identify refer to Identify the product and its version for Acrobat and Reader DC
Is it a Mac or Windows machine and what is the version?
Is it specific to one PDF that it's size increases when you use the certificate of with all the PDF files?
let us know how it goes and share your observation.
Anand Sri.
Hi Anand,
version of my adobe reader is Adobe Acrobat Reader DV - Slovak (18.011.20055), im on Windows 7 Professional, 64 bit. I have the same problem with all PDF files after digital sign. For example i made empty PDF with size 78,8kB, after digital signature it has 3,07MB.
Regards
Ondrej
Dear Anand,
i tried to use the solution from Electronically signing PDF file increases file size by approximately 3 MB
The truth is that after apply this procedure, the size after sign was ok, but there was other problem with validation:
So now i have two possible states after digital sign but both are bad - big size document or normal size document with invalid signature...
Regards
Ondrej
any other ideas? My friend has the same electronical sight and work OK with normal size, only one difference is thet he is using Win 10 and i have Win 7.
Regards
Ondrej
Hello Ondrejn,
We're sorry for the delayed response and inconvenience caused. Are you still experiencing the issue or it is fixed?
Install the latest patch of Adobe Reader and check DC Release Notes — Release Notes for Acrobat DC Products
I assume there is a possibility when the first signer signed the document the document got locked. To check open the document in Reader or Acrobat, click on File>Properties>Security tab. Check if you have permissions to sign the document.
If the issue persists, remove Adobe Reader using Acrobat Cleaner tool Download Adobe Reader and Acrobat Cleaner Tool - Adobe Labs
Reboot the machine and install the latest version of Adobe Reader from Adobe - Adobe Acrobat Reader DC Distribution
Anand Sri.
