6 Replies Latest reply on Jul 16, 2018 7:37 AM by Bill Silbert
    Find and replace Panel
    VeluVK Level 1
      I have a some problem in find & replace pannel. Pannel is exceeded to length. i cant able to do anything.  Please suggest
      Velu
        • 1. Re: Find and replace Panel
          Abambo Adobe Community Professional
          What is your version of Indesign, what is your OS and version. This looks like an incompatibility between the OS and Indesign.
          • 2. Re: Find and replace Panel
            Dan Rodney Adobe Community Professional
            Try the Restore all preferences and default settings found here: Set preferences in Adobe InDesign and it may fix the issue.
            1 person found this helpful
            • 3. Re: Find and replace Panel
              VeluVK Level 1
              Hi Abambo,
              I have using InDesign CC 2014 windows version.
              Velu
              • 4. Re: Find and replace Panel
                Bill Silbert Adobe Community Professional
                Problems with panels can many times be solved by trashing your InDesign Cache files—which is not the same as trashing preferences.
                To do so:
                For Macintosh Users: With InDesign closed launch a Finder Window in column view and click on your home folder. With the Option Key pressed choose Library from the Finder Go Menu. Within the Library folder find the “Caches” folder. Within the Caches folder find and delete the entire folder “Adobe InDesign”. I find that deleting the InDesign cache folder completely leads to a lasting change.
                For Windows Users: On Windows 7 and above the caches files are hidden. To find them go to the Control Panel and open Folder Options and then click the View tab. Then select “Show hidden files and folders” or “Show hidden files, folders or drive options” in Advanced Settings. Then delete (or rename) the folder at the end of this path: C:\Users\[User Name]\AppData\Local\Adobe\InDesign\Version [#]\<Language>\Cache.
                EDIT: You can also try to go under the Workspace Menu and use the Reset "Whatever Workspace you're using" option and see if the Panel resets.
                • 5. Re: Find and replace Panel
                  VeluVK Level 1
                  Thanks Bill,
                  I have deleted the cache files, now its getting solved the issue.
                  Thanks for your help.
                  Velu
                  • 6. Re: Find and replace Panel
                    Happy to help.
