I have same problem i can not save files any more since i installed Microsoft Office 2016
Please give details:
Which version of Acrobat?
Which files can't you save?
What steps do you use when you try to save?
What is the error message?
Windows or Mac? Which version?
Which version of Acrobat? ADOBE ACROBAT XI PRO
Which files can't you save? ANY PDF FILES NEW OR OLD
What steps do you use when you try to save? I TRIED TO SCAN NEW DOCUMENTS GO TO SAVE AS
TRIED OPENING A PDF FILE EDIT IT AND SAVE
What is the error message?FILE CAN NOT BE SAVED MAY BE OPEN IN ANOTHER PROGRAM(THE ALL OPEN LIKE THE FILES ARE IN READ ONLY FORMAT WHICH THEY ARE NOT.
Windows or Mac? Which version? WINDOWS 10 HOME
Hi fred40fl,
As per the issue description mentioned above, you are facing issue when trying to save pdf files, is that correct?
Try the troubleshooting steps in the following forum thread under post# 6:
Error: The file may be a read only, or another user has it open.
You may also refer to the following forum thread discussing the similar issue:
File cannot be saved because it is currently open in Acrobat.exe.
Let us know if you need any help.
Shivam
