1
Blurry/fat text in Indesign vs Acrobat
Jul 10, 2018 Jul 10, 2018
I've found that the text in IndesignCC is fat/blurry. See compared to the same file output in Acrobat. See photo, Acrobat on the left and Indesign on the right.
IndesignCC 13.1
Windows 10
NVidia Graphic
Any idea why this would be happening and how to fix it?
6.7K
Try this in InDesign: View > Display Performance > High Quality Display.
If that works, do it with no documents open and it will become the default setting.
Hi there,
Thanks for the suggestion but I think that command only impacts images and not the actual text. (I tried it and it did not impacts the text at all) The text really seems to be the problem here.
Go to the Layers panel, and ensure the text Layer is moved to the top (you can use the twirl down to reveal the layers).
Hmmm I moved the text to the top layers but sadly it is still blurry...
I'm wondering if it has something to do with how windows 10 handles larger screens? I have a HP Omen 32 maybe it's just a terrible monitor for graphic design?
It's curious matter, does this happen on all InDesign documents?
Yes, all Indesign documents the text look rather bad.
Jul 11, 2018 Jul 11, 2018
A client of mine had a similar issue last year. This thread may help:
InDesign runs at a weird resolution - Microsoft Community
If the answer wasn't in my post, perhaps it might be on my blog at colecandoo!
Well this was certainly something I didn't know about so thank you for pointing it out. I tried a couple of the setting suggested but nothing seemed to change! I'm starting to wonder if I'm just crazy.
Do you have any scaling set in the operating system? Is the monitor running at its native resolution? Is it a single monitor or dual monitors? Finally, what version of Windows 10 are you running?
Jul 12, 2018 Jul 12, 2018
Scaling is set at 100% and the monitor is running at native resolution 2560x1440 pixels. It is a single monitor and it is Windows 10 Pro (most recent build)
Is 2560x1400 just a bad resolution for a 32 in monitor???
I have two Dell QHD monitors running at that resolution. My second one is set to 125% but the main monitor is set to 100%. When I drag panels or a file to the second monitor it’s noticeably blurry.
In your InDesign prefs, do you have UI scaling turned on?
Where do you check the UI scaling? Is that under the Indesign properties?
Do you find that the text on your main monitor is looking nice and crisp? I'm thinking it could be a problem with Indesign itself because the the same file in Acrobat looks better then the original file in Indesign...
Absolutely beautiful on my main monitor.
Edit > preferences > UI Scaling
I tried both options under UI Scaling and neither helped. Does this UI scaling impact the type used in the document? That is what is looking thick and fuzzy...
Jul 13, 2018 Jul 13, 2018
I was taking a shot in the dark.
Can you upload screenshot the is more zoomed in on the text? I see no difference in the screenshot you uploaded before.
Jul 14, 2018 Jul 14, 2018
That looks more like an anti aliasing thing.
It’s difficult to judge. Yo may be right.
ABAMBO | Hard- and Software Engineer | Photographer
So, is there anything that can be done about anti aliasing? I guess I want to know if there is something wrong with Indesign or my computer's settings or is that just the way it is? I'm used to an iMac 5K at work and maybe I'm just spoiled by that? Are my expectations for crisp text on a 2560x1440 out of line? If I was to get a higher resolution monitor  (say 3840 x 2160) would that make the text more crisp? I'm just concerned that because I'm running Windows 10 that it can't take advantage of those pixels and it's money wasted?
Jul 15, 2018 Jul 15, 2018
You can turn Anti-aliasing on and off in the Display Performance section of Preferences.
The real question would be how did that get turned off.
Jul 16, 2018 Jul 16, 2018
Thanks for the information. Strangely, it was still on so I guess it's not an Anti-aliasing issue??
Apr 21, 2021 Apr 21, 2021
Having the same problem...   ...almost!
On all, ALL, InDesign project that I do everything is fine until my last page. The text on those last page seem non-anti-aliased. When I export those documents, the fonts on the last page are all weird/fuzzy. I've search solution and tried all of them, and nothing work!
I'm working on Windows10!
