I use Elements 12 and cannot open any files because I received an error message "Could not import the clipboard because an unexpected end-of-file was encountered."
how does this get fixed??
You have updated Windows 10 recently to (1803)?
Then you have been hit by the Microsoft bug: see the explanation and solution:
Error: An integer between 50 and 8 is required | Elements | Windows 10
I have the same issue. Has worked fine up until now. I've tried the fixes I have found online and still not working. Very annoying, any one have an answer for this?
We don't have a clue what you have tried.
See this:
I've uninstalled and reinstalled Photoshop Elements. I've reset the settings.
What can I do? I've used the clipboard thousands of times and suddenly this error comes up. I Googled the error message and it comes up as a common issue, but there doesn't seem to be an actual fix posted anywhere.
Actually the entire program seems to be running slower as well. I just tried opening a picture and now I get... "Could not complete your request because of a problem parsing JPEG Data"
I can open the photo with microsoft and paint.
I haven't noticed any issue with any of my other programs on my computer, just PhotoShop Elements has broken down.
Thank you very much. I completely forgot about those updates. This fixed the issue.
