I have been looking for a way to batch change Canon Cinema Raw Light settings to multiple clips in the timeline. You can copy the settings but can only paste them to one clip at the time. It takes a long time to lower exposure by 0.5 Stops on 100 clips
Wont Paste Attributes work?
Just tested it, it doesn't work.
Is this a plugin you put on the master clip?
It is not a plugin it is a native master effect to control .crm files settings
Not sure if this is going to work.
MIght try to do one clip,
Copy in the Project panel.
Select multiple clips in project panel and Paste.
JEDylan,
Did you try what Ann suggested? Let us know if that worked for you or not.
Kevin
Nop it didn't work I tried all of the solutions suggested above
Seems to work fine for me when I copy the "Cinema Raw Light Source Settings" and paste them over clips in the project panel.
The problem I have is I want to change the gamma only, but it also copies the temp/tint settings to every clip, making the whole thing pointless
Does anyone know a work around for this?
