Auto vertical and horizontal Align script
Jul 12, 2018 Jul 12, 2018
First of all - I'v maded few hours of search (this forum and google).
I was found script which is almost doing what i want: Peter Kahrel -- Free script | Align objects
But i would like to have easier (faster) scirpt:
What i would like to have:
I would like select 2 objects - and by one click align them vertical and horizontl.
Default using Adobe tool i must always make two clicks for both options.
Do you know maybe how i can do that?
Best Regards
Jarek
Scripting
8.3K
Community Beginner , Jul 15, 2018 Jul 15, 2018
Thanks to Peter Kahrel who made this one  Peter Kahrel -- Free script | Align objects​
I was ask him is there any chance to make modification.
So he did it - and i'm very helpfoul for him.
So - what i maded with this? I was created shortcut CTRL+SHIFT+C and attached script:
And now what i have ?:D
When i select two object's i can simply pres shorcut described above and have aligned two objects
Mr. Peter Kharel - thank you for all - Your are Amazing!!!
(BTW: First selected object is "key object")
I know this is not a scripting solution but in CC 2018 (I haven't checked other versions) if you use quick apply - it defaults to the align options when you have 2 or more objects selected, that is just Cmd(Ctrl) + Return and then type or click to get the one you want, I don't' see a script making it much faster than that, but it maybe someone on here has a faster solution.
Regards
Malcolm
Guide ,
Jul 13, 2018 Jul 13, 2018
Maybe I'm wrong! …
According to me, there're 9 configurations [alignments, no distributions]!
So 9 simplistic 2-lines scripts, whose name is associated to a number of the keypad!
7 8 9
4 5 6
1 2 3
… so, e.g., "horizontal-centers alignment + vertical-centers alignment" would be:
app.activeDocument.align (app.selection, AlignOptions.HORIZONTAL_CENTERS);
app.activeDocument.align (app.selection, AlignOptions.VERTICAL_CENTERS);
Its name: 5_H-Center--V-Center.jsx
I could give you the 8 other scripts but I'm too lazy for that!
Welcome to the party!
Best,
Michel, For FRIdNGE
Enthusiast ,
Here is the script for AppleScript:
tell application "Adobe InDesign CC 2018"
  set selList to selection --assumes more than one item selected
  tell document 1
  align align distribute items selList align option horizontal centers
  align align distribute items selList align option vertical centers
  end tell
end tell
Put the script with your scripts in the Scripts panel and give it a keyboard shortcut (maybe Command + Shift + A) for one-stroke functionality. Keyboard Shortcuts are found under Edit in InDesign's menu.
So this might by good script - but in windows isn't work
  tell document 1
  end tell
end tell
Jul 14, 2018 Jul 14, 2018
https://forums.adobe.com/people/Michel+%5BFRIdNGE%5D  wrote
… Welcome to the party!
Hi Michel,
see also into method distribute() and property selectionKeyObject of object Document.
Uwe
// DESCRIPTION Align frames CorelDraw-style: last selected frame is target
// Peter Kahrel
var obj = app.selection;
if( obj.length < 2 ) {
errorM('Select at least two objects');
function errorM( m ){
alert( m );
exit()
function getPosition( o, pos ) {
switch( pos ) {
case 'top' : return o.geometricBounds[0];
case 'left' : return o.geometricBounds[1];
case 'bottom' : return o.geometricBounds[2];
case 'right' : return o.geometricBounds[3];
case 'hcentre' : return o.geometricBounds[1] +
((o.geometricBounds[3] - o.geometricBounds[1]) / 2);
case 'vcentre' : return o.geometricBounds[0] +
((o.geometricBounds[2] - o.geometricBounds[0]) / 2);
function align_hor( obj, source_align, target_align ){
var target = getPosition( obj[0], target_align )
for( var i = 1; i < obj.length; i++ ) {
obj.move( undefined, [target - getPosition(obj,source_align), 0], true );
function align_vert( obj, source_align, target_align ){
[0, target - getPosition(obj,source_align)], true )
function alignFrames (type) {
switch (type) {
// horizontal alignment
case 'RL' : align_hor( obj, 'right', 'left'); break;
case 'RC' : align_hor( obj, 'right', 'hcentre'); break;
case 'RR' : align_hor( obj, 'right', 'right'); break;
case 'CL' : align_hor( obj, 'hcentre', 'left'); break;
case 'CCH' : align_hor( obj, 'hcentre', 'hcentre'); break;
case 'CR' : align_hor( obj, 'hcentre', 'right'); break;
case 'LL' : align_hor( obj, 'left', 'left'); break;
case 'LC' : align_hor( obj, 'left', 'hcentre'); break;
case 'LR' : align_hor( obj, 'left', 'right'); break;
// vertical alignment
case 'BT' : align_vert( obj, 'bottom', 'top'); break;
case 'BC' : align_vert( obj, 'bottom', 'vcentre'); break;
case 'BB' : align_vert( obj, 'bottom', 'bottom'); break;
case 'CT' : align_vert( obj, 'vcentre', 'top'); break;
case 'CCV' : align_vert( obj, 'vcentre', 'vcentre'); break;
case 'CB' : align_vert( obj, 'vcentre', 'bottom'); break;
case 'TT' : align_vert( obj, 'top', 'top'); break;
case 'TC' : align_vert( obj, 'top', 'vcentre'); break;
case 'TB' : align_vert( obj, 'top', 'bottom'); break;
default : errorM('Illegal input.')
alignFrames ('CCH');
alignFrames ('CCV');
//~ function alignType(){
//~ var dlg = app.dialogs.add( { name: 'Align' });
//~ with( dlg.dialogColumns.add() )
//~ with( borderPanels.add() )
//~ var userSelect = textEditboxes.add( { editContents : 'CCH' } );
//~ if( dlg.show() )
//~ var temp = userSelect.editContents;
//~ dlg.destroy();
//~ return temp;
//~ else
//~ dlg.destroy();
//~ exit();
So we can close ticket as it is fixed
Jul 16, 2018 Jul 16, 2018
It's greate! but - objects are moving from place.
I was posted script maded by: Peter Kahrel​ which is more useful.
But thank you for advice It's pretty nice to recive some help.
jarosÅ‚awz53072541  wrote
… but - objects are moving from place.
Hi Jaroslaw,
they do because there is no selectionKeyObject in the selection.
And it is also not defined in the script by Michel. Assumption: Neither it is defined by the user, you.
Michel's script run on two objects selected where no selectionKeyObject is applied to the selection:
If Michel's script would work with selectionKeyObject and selectionKeyObject would have been defined by the user with an extra click:
Note: method align() has 4 arguments that are relevant if there is a selectionKeyObject.
If there is and you are using Michel's script it will throw an error message.
Here a different version of Michel's script that is working with or without a selectionKeyObject:
( function()
    app.scriptPreferences.userInteractionLevel = UserInteractionLevels.INTERACT_WITH_ALL;
    app.doScript
        alignCenterCenter,
        ScriptLanguage.JAVASCRIPT,
        UndoModes.ENTIRE_SCRIPT,
        "Align Selection Center-Center | SCRIPT"
    function alignCenterCenter()
        if( app.documents.length == 0 ){ return };
        if( app.selection.length < 2 ){ return };
        var doc = app.activeDocument;
        if( doc.selectionKeyObject == null )
            doc.align(  app.selection , AlignOptions.HORIZONTAL_CENTERS );
            doc.align(  app.selection , AlignOptions.VERTICAL_CENTERS );
            return;
        doc.align( app.selection , AlignOptions.HORIZONTAL_CENTERS , AlignDistributeBounds.KEY_OBJECT , doc.selectionKeyObject );
        doc.align( app.selection , AlignOptions.VERTICAL_CENTERS , AlignDistributeBounds.KEY_OBJECT , doc.selectionKeyObject );
Uwe
Thank you But Peter script automatically set "key object" as first selected item.
So there isn't necessary to choose from panel align "key object" simply this making script maded by Peter.
Hi Jaroslaw,
the one above could be useful if you selected all objects you want to align and did not make up your mind or you changed your mind on the object you want the others align to. 🙂
Best,
Uwe
So they end up on top of each other, centered on the center point? If that is not what you mean, show a "before/after" image.
