I am inserting a file into a sequence that is 1920*1080
The file resolution is: 2048*858
When I drag an drop it in the sequence, it comes rotated automatically 90 degrees clockwise.
I check the effects control tab, nothing is there
It looks like you have Rotation there in the ECP ... Motion, under it Position, Scale, a line or two break for a control, then Rotation ... ?
If you can see in the video embed. that the rotation degree is 0
Change the rotation so it is properly oriented.
it should not be rotated like this when inserting its a horizontal shot
Set it to 90.
Either that or go into the Properties panel for the media, and change things there.
Neil
Averdahl has the good answer about this being a bug, and yes, please do file the report. The new system is a vast improvement. It's something needing a fix.
PeruBob and I were interested in the immediate practical issue to get you running at the moment ...
Neil
I think the practical issue i crystal clear: Footage is imported correctly as 2048x858 but when placed on timeline the footage auto-rotates for no obvious reason to 858x2048 making editing a pain since each clip must manually rotated. Many clips, many adjustements. Nothing can be changed in either the Properties panel or by using Interpret Footage.
Akurat.
But I believe one can select all clips like this on a sequence and change them at one go ...
Neil
No and yes. By default it is not possible to rotate multiple clips, but if one create a Preset and set the Rotation to 180 it is possible. But, what happen when the update that fixes this arrive?
It´s a known issue and i hope the next update will adress it.
Add your vote and comment here: Bug - Smartphone footage is rotated in CC2018 when importing CC2017 project – Adobe video & audio ap...
but it is not a mobile shot
Maybe the project just needs trashing the preferences as the sequence setting also changes eventhough you clicked Keep Settings.
FAQ: How to reset preferences in Premiere Pro? | Adobe Community
It happens to other cameras as well. Some days ago someone reported the same issue with an Arri camera. (don´t remeber the model.)
A media info screenshot in treeview is always instructive, even if it simply confirms your description of its native characteristics.
attached
Please use MediaInfo Mac
I dont want to be a pest, but in treeview as Stan requested.
hi
no worries at all
thanks for the help
i tried downloading treeview from here
http://taxonomy.zoology.gla.ac.uk/rod/treeview.html
but dunno what to do next
No ... it's in MediaInfo, you can view the information in quite a few different formats ... it's their Tree view. As below ... just ignore the red marks, they were to highlight something for another user.
Neil
Done
Have you tried trashing preferences?
yes
same issue
The persistence award!
And yes, I see nothing in the properties that should cause an issue. (There is a rotated flag that is not present here.)
To clarify, in your youtube demonstration in the original post, the asset in the project panel shows as "incorrect" - it is 858x2048, not 2048x858. So it imported incorrectly? - Unlike Averdahl's bug, which imports correctly? And in any event was for a previous project being imported. I'm not questioning the bug or whether this is a variant, just wanting to understand.
Eliei, can you post a sample?
Averdahl, I get an error when I try to get your sample file. But you are saying that the asset file imports correctly?
