Hi all,
Seeing an extremely strange issue in Premiere when working out of a SMB share. The SMB server is a FreeNAS 11 box. Clients are MacOS El Capitan.
The issue is that when one clicks the first SMB share in the Premiere file browser one is prompted for credentials for the alphabetically first user on the FreeNAS box.
If the credential dialog is closed everything is usable; doesn't appear that credentials are needed. Everything is browsable in Finder.
Clicking any other share or any subfolder of the first share doesn't generate the credential prompt.
I've confirmed that the share in question has identical permissions when compared to the others.
It's not a weird issue with the project file as the issue is reproducible with a new, blank project.
Anybody seen anything like this before?
Hi ITS,
Have you contacted the VAR who set up this shared media system yet? Sorry, but this issue is beyond my expertise. I don't have a shared media system similar enough to run any tests for you either. I will ask around for you, though.
I will say that we experience a lot more trouble with groups trying to run multiple systems on a NAS, as more things can go wrong with them with digital video. Usually, groups are much more successful with a SAN, from what I've observed.
Hope we can get another user here to chime in.
Kevin
Thanks for your response.
This issue sits at the confluence of a number of issues which makes it tricky for our VAR to take full responsibility.
For example usually the OS would mount the network share and then present the storage to applications on the system.
What is strange here is that the share is completely accessible and requires no extra credential dialogs in any software other than Premiere. This makes it look like a Premiere issue.
