Hi there,
This bug has happening for some time - I believe it started in Bridge CC 2017 but it is still present in this version. So I’m not sure if it is 100% related to Bridge.
Situation: the shortcut Cmd+Q to quit Bridge works fine, up until the moment I've hidden the app. After that Cmd+Q (Quit) won't work to quit.
I've checked my system shortcuts, but nothing interferes with this shortcut. Cmd+Q works fine on other apps (Illustrator, Photoshop, Indesign,… all quit when using the shortcut). Also all other shortcuts do seem to work in Bridge, it's just the Cmd+Q that doesn't do anything.
Like I said, it might not be related to Bridge since trashing preferences or reinstalling doesn't change anything. Also the same bug has been going on since a few versions.
Would be nice to get some feedback on possible cause (and solution) for this
Thank you!
Not big chance they are going to do something about. What I noticed Br team from 10 years ignores their users regarding bugs they introduced they were not part of program earlier. I noticed you found a reason of this bug that is not said in that report. Now you know it happnes when you firstly use cmd h (to hide Photoshop). Maybe if you mention that they won't be enough lazy to find it themselves. Then beeing aware of reason they can fix it. Btw I wanted to search for this problem there but the
...Copy link to clipboard
Report it: Bridge | Photoshop Family Customer Community
It's there already
Bridge: Cmd-Q won't quit application | Photoshop Family Customer Community
No solution so far…
Not big chance they are going to do something about. What I noticed Br team from 10 years ignores their users regarding bugs they introduced they were not part of program earlier. I noticed you found a reason of this bug that is not said in that report. Now you know it happnes when you firstly use cmd h (to hide Photoshop). Maybe if you mention that they won't be enough lazy to find it themselves. Then beeing aware of reason they can fix it. Btw I wanted to search for this problem there but there's too bad search so just gave you link to site. If that bug was on Windows I could easily fix it, not on Mac.
Btw I found similar bug on Wndows with Photoshop. After I use WIN D to hide Ps (in order to go to desktop) and then I'm back to program I can not use CTRL (SHIFT) TAB to change active document to (previous) next one(s). Probably because noone beside me reported it they are not going to fix it. The worst is it's fresh bug that wasn't part of Ps before CC 2018, so they should be obligated to sort it out fastly. Unfortunately I don't see they care of, especially that is something easy to fix.
Broken behaviour of 'control tab' / 'command tilde' to cycle through minimised documents in CC 2018 ... (3 months waiting! For your case it's 7 years!)
Okay, I'll give it go then. I'll copy my findings in the other thread.
Fingers crossed!
Thanks for the feedback.
