I have a client who requires a digital screen updating in store, and they have sent me through the following specs.
Dimensions (W x H) | 768mm x 2784mm estimated |
Total Resolution | 256 (w) x 928 (h) |
LED Pitch/Screen Size | 3mm 2.138m² |
LED Type | SMD, 2020 1R 1G 1B Per Dot |
Total Number of Pixels | 237,568 SMD tile size 192mm x 96mm |
Grey Scale | 16 Bit with Exclusive PWM drivers for better colour images |
Display Brightness | 0-1400 Mcd |
Display Power | 290 watts per Sq m Running, on start-up 850 per Sqm Max |
Screen Refresh Frequency | 1000Hz+ |
Frame Update Frequency | 60Hz |
Can anyone advise me on how i should set my Premiere Pro cc document and the best settings to use. I require a mpg4 to output.
Thank you to anyone who can help me.
Only just started to use Premiere Pro so trying to still wrap my head around it all.
Kind regards
Yes, if your videos are already made, your only option is to use the scale so they fit on your screen.
What exactly do you need to know? What your client has sent you are the specifications of your TV.
Hi Byroncortezh,
I think I kind of answered my own question by playing around. However, I have some pre created video to place into these dims which are not to the spec. Is my only option to get them to fit to play around with the scale option for the best fit?
