Huy guys, I could really use some help here.
Do you have adequate handles?
Yes, each shot is long enough to fill the template
Can you post a link to the template?
Sure, its a motion array template though so, unfortunately, it requires a subscription to download. --> Seamless Transitions - Premiere Pro Templates | Motion Array
Also here is a clip of my issue
Delete the Media Cache and Media Cache Files.
If that doesn't work, try Sequence > Render Entire Work Area. The yellow bar should turn green.
If that doesn't work, try contacting Motion Array Support:
That doesn't do it unfortunately 😕
I would try it, but I only have the free membership.
Did you try contacting Motion Array Support?
Yes, they suggested I go to the "wrench icon" and click reveal markers because there's a certain point in the clip that the maker has markers on, but I already have "show markers" selected. They sent me a screenshot of the same pack with a red marker on the sequence... but I still don't see it so now I'm facing a new problem of revealing the markers. Any ideas on this front?
What number version of Premiere Pro are you using?
