MacOS Mojave disabled some functions
Jul 07, 2018 Jul 07, 2018
After installing Mojave, I noticed a number of Lightroom Classic Functions disabled:
1. Basic: Vibrance & Saturation disabled
2. HSL/Color/B&W: all functions disabled
3. Detail: all functions disabled except sharpening amount, noise reduction, luminance/color
4. Len correction: defringe
5. Effects: all functions disabled except amount
Do others have this problem?
Besides reinstalling MacOS High Sierra, any other options?
Many thanks.
1.9K
The release date for mojave is this fall... likely will be buggy for a bit.
Many of Apples apps won't work on mojave yet... https://www.macworld.co.uk/feature/mac-software/apps-work-macos-mojave-3678735/
This looks an awful lot like another problem, totally unrelated to MacOS Mojave. Could you go to the Lightroom 'Help - System Info' menu and tell us what it says behind 'License' (or post a screenshot)?
-- Johan W. Elzenga
You really ought to state the version NUMBER of your Lightroom (we need the NUMBER and not words like "latest")
Nevertheless, there are other reports of Lightroom not working properly on OSX 10.14, so it could be that is the problem.
The version number is not enough. We need the first lines of the 'System Info' menu to be sure this is not another problem that we encounter here quite often. It could indeed be MacOS Mojave (the latest version of Lightroom is not officially compatible), but we need to be sure.
-- Johan W. Elzenga
Jul 19, 2018 Jul 19, 2018
Many thanks for the help. Here's the system info:
Lightroom Classic version: 7.4 [ 1176617 ]
License: Perpetual
Language setting: en-SG
Operating system: Mac OS 10
Version: 10.14.0 [18A336e]
Application architecture: x64
Logical processor count: 4
Processor speed: 2.7 GHz
Built-in memory: 8,192.0 MB
Real memory available to Lightroom: 8,192.0 MB
Real memory used by Lightroom: 1,414.6 MB (17.2%)
Virtual memory used by Lightroom: 2,410.9 MB
Memory cache size: 33.7MB
Internal Camera Raw revision: 976
Maximum thread count used by Camera Raw: 3
Camera Raw SIMD optimization: SSE2,AVX,AVX2
Camera Raw virtual memory: 836MB / 4095MB (20%)
Camera Raw real memory: 848MB / 8192MB (10%)
Displays: 1) 3360x2100
Graphics Processor Info:
Metal: Intel(R) Iris(TM) Graphics 6100
Application folder: /Applications/Adobe Lightroom Classic CC
Library Path: /Users/lihaozhuang/Pictures/Lightroom/Lightroom Catalog-2.lrcat
Settings Folder: /Users/lihaozhuang/Library/Application Support/Adobe/Lightroom
Installed Plugins:
1) Aperture/iPhoto Importer Plug-in
2) Canon Tether Plugin
3) Facebook
4) Flickr
5) HDR Efex Pro 2
6) Nikon Tether Plugin
Config.lua flags: None
AudioDeviceIOBlockSize: 512
AudioDeviceName: Built-in Output
AudioDeviceNumberOfChannels: 2
AudioDeviceSampleRate: 44100
Build: 10.0x7
CoreImage: true
GL_ACCUM_ALPHA_BITS: 0
GL_ACCUM_BLUE_BITS: 0
GL_ACCUM_GREEN_BITS: 0
GL_ACCUM_RED_BITS: 0
GL_ALPHA_BITS: 8
GL_BLUE_BITS: 8
GL_DEPTH_BITS: 24
GL_GREEN_BITS: 8
GL_MAX_3D_TEXTURE_SIZE: 2048
GL_MAX_TEXTURE_SIZE: 16384
GL_MAX_TEXTURE_UNITS: 8
GL_MAX_VIEWPORT_DIMS: 16384,16384
GL_RED_BITS: 8
GL_RENDERER: Intel(R) Iris(TM) Graphics 6100
GL_SHADING_LANGUAGE_VERSION: 1.20
GL_STENCIL_BITS: 8
GL_VENDOR: Intel Inc.
GL_VERSION: 2.1 INTEL-12.0.17
OGLEnabled: true
GL_EXTENSIONS: GL_ARB_color_buffer_float GL_ARB_depth_buffer_float GL_ARB_depth_clamp GL_ARB_depth_texture GL_ARB_draw_buffers GL_ARB_draw_elements_base_vertex GL_ARB_draw_instanced GL_ARB_fragment_program GL_ARB_fragment_program_shadow GL_ARB_fragment_shader GL_ARB_framebuffer_object GL_ARB_framebuffer_sRGB GL_ARB_half_float_pixel GL_ARB_half_float_vertex GL_ARB_instanced_arrays GL_ARB_multisample GL_ARB_multitexture GL_ARB_occlusion_query GL_ARB_pixel_buffer_object GL_ARB_point_parameters GL_ARB_point_sprite GL_ARB_provoking_vertex GL_ARB_seamless_cube_map GL_ARB_shader_objects GL_ARB_shader_texture_lod GL_ARB_shading_language_100 GL_ARB_shadow GL_ARB_sync GL_ARB_texture_border_clamp GL_ARB_texture_compression GL_ARB_texture_compression_rgtc GL_ARB_texture_cube_map GL_ARB_texture_env_add GL_ARB_texture_env_combine GL_ARB_texture_env_crossbar GL_ARB_texture_env_dot3 GL_ARB_texture_float GL_ARB_texture_mirrored_repeat GL_ARB_texture_non_power_of_two GL_ARB_texture_rectangle GL_ARB_texture_rg GL_ARB_transpose_matrix GL_ARB_vertex_array_bgra GL_ARB_vertex_blend GL_ARB_vertex_buffer_object GL_ARB_vertex_program GL_ARB_vertex_shader GL_ARB_window_pos GL_EXT_abgr GL_EXT_bgra GL_EXT_blend_color GL_EXT_blend_equation_separate GL_EXT_blend_func_separate GL_EXT_blend_minmax GL_EXT_blend_subtract GL_EXT_clip_volume_hint GL_EXT_debug_label GL_EXT_debug_marker GL_EXT_draw_buffers2 GL_EXT_draw_range_elements GL_EXT_fog_coord GL_EXT_framebuffer_blit GL_EXT_framebuffer_multisample GL_EXT_framebuffer_multisample_blit_scaled GL_EXT_framebuffer_object GL_EXT_framebuffer_sRGB GL_EXT_geometry_shader4 GL_EXT_gpu_program_parameters GL_EXT_gpu_shader4 GL_EXT_multi_draw_arrays GL_EXT_packed_depth_stencil GL_EXT_packed_float GL_EXT_provoking_vertex GL_EXT_rescale_normal GL_EXT_secondary_color GL_EXT_separate_specular_color GL_EXT_shadow_funcs GL_EXT_stencil_two_side GL_EXT_stencil_wrap GL_EXT_texture_array GL_EXT_texture_compression_dxt1 GL_EXT_texture_compression_s3tc GL_EXT_texture_env_add GL_EXT_texture_filter_anisotropic GL_EXT_texture_integer GL_EXT_texture_lod_bias GL_EXT_texture_rectangle GL_EXT_texture_shared_exponent GL_EXT_texture_sRGB GL_EXT_texture_sRGB_decode GL_EXT_timer_query GL_EXT_transform_feedback GL_EXT_vertex_array_bgra GL_APPLE_aux_depth_stencil GL_APPLE_client_storage GL_APPLE_element_array GL_APPLE_fence GL_APPLE_float_pixels GL_APPLE_flush_buffer_range GL_APPLE_flush_render GL_APPLE_object_purgeable GL_APPLE_packed_pixels GL_APPLE_pixel_buffer GL_APPLE_rgb_422 GL_APPLE_row_bytes GL_APPLE_specular_vector GL_APPLE_texture_range GL_APPLE_transform_hint GL_APPLE_vertex_array_object GL_APPLE_vertex_array_range GL_APPLE_vertex_point_size GL_APPLE_vertex_program_evaluators GL_APPLE_ycbcr_422 GL_ATI_separate_stencil GL_ATI_texture_env_combine3 GL_ATI_texture_float GL_ATI_texture_mirror_once GL_IBM_rasterpos_clip GL_NV_blend_square GL_NV_conditional_render GL_NV_depth_clamp GL_NV_fog_distance GL_NV_light_max_exponent GL_NV_texgen_reflection GL_NV_texture_barrier GL_SGIS_generate_mipmap GL_SGIS_texture_edge_clamp GL_SGIS_texture_lod
It's unlikely that Lightroom will run properly on OSX 10.14 at this time.
That’s what I thought. You have this problem of having 'upgraded' a perpetual license of Lightroom 6 to Lightroom Classic somehow. That upgrade should never have been possible, because you do not have a subscription but a perpetual license (for Lightroom 6). There is no perpetual license for Lightroom Classic and there is no Lightroom 7. Due to a bug in the updaters it was somehow possible to install Lightroom Classic without having a subscription, and this now causes all kinds of problems (you’ve just been lucky that it didn’t happen earlier, when you first started with the upgraded version).
The solution is to go back to Lightroom 6, the version you have a license to use. In order not to lose all the work you may have done since your first update, select all the images that were imported after you updated to Classic and choose 'Metadata - Save Metadata to Files'. Then open Lightroom 6 with your old Lightroom 6 catalog, and import these images. The edits and metadata should come over, except those edits that are new for Lightroom Classic (like Range Mask). You can find the correct installers and updaters here:
https://helpx.adobe.com/lightroom/kb/lightroom-downloads.html
Or, of course, you can take a subscription to Lightroom Classic after all. In that case you need to fully uninstall Lightroom, and then reinstall it after the subscription has come into effect and you’ve logged in with your Creative Cloud credentials. Your catalog will not be affected by uninstalling/reinstalling.
Also please go here to help Adobe sort out this mess: Log Collector Tool
-- Johan W. Elzenga
I don't think it will work properly under Mojave, even after the licensing is straightened out.
Maybe it won't, but this 'Frankenstein' Lightroom version won't work properly on any MacOS X version.
-- Johan W. Elzenga
