Hi there,
Earlier today I used the Publish Online feature in InDesign for the first time... I uploaded 2 documents with no issues.
I've then had to amend those documents, so I've gone to upload to existing documents and it's not getting past 0%
The initial upload process was quite quick - is it usually noticeably longer to upload to existing or do you reckon there is an error of somesort?
Also, is there a way to rename the URL generated?
Thanks in advance (I did try searching the forum before I posted this message)
Hi there,
We are very sorry to hear about this. I would request you to please try steps mentioned here; Upload error while publishing InDesign document and share results.
Srishti
you cannot rename the URL that is generated.
What you can do is using a shortener service for the URL for publishing the URL somewhere.
If you cannot get past 0% of uploading I don't think you can do much than trying again after a while.
Uwe
Hi there,
Srishti
